Thread: KR Question??
Results 21 to 40 of 59
  1. #21 Re: KR Question??
    Outer Space
    sounds like your tune is off or you have a small vac leak which is forcing the car to run lean.
    That's what I am thinking. If I was you, I wouldnt go WOT until you get this addressed. If there any local tuners...see if you can get them to tune ya.
    02 GTP 13.6 @ 100mph - SOLD
  2. #22 Re: KR Question??
    SE Level Member iluvbst's Avatar
    kissimmee,fl
    but my car is stock...i dont have an tunable ecu...unless the stock one is tunable...sorry for the noobness lol...i know alot about cars, but new to these...
  3. #23 Re: KR Question??
    Willoughby, Ohio
    ecu=pcm for these cars (Powertrain Control Module) just for future reference
    if its stock you can get it reflashed at the stealership
  4. #24 Re: KR Question??
    kissimmee,fl
    and what would that do for me? reinstall the stock tune?
  5. #25 Re: KR Question??
    it would do nothing. if your car is stock then something is wrong. im still leaning vac leak.
  6. #26 Re: KR Question??
    kissimmee,fl
    ok thats what i was thinking..going to do some more test..back in a bit.
  7. #27 Re: KR Question??
    Willoughby, Ohio
    right, check yourself first and be pretty sure the PCM is screwin up before you pay to have it done
  8. #28 Re: KR Question??
    kissimmee,fl
    what should the vac be at on these cars? i just did another vac test, and blocked off a suspected hose, and still the same 18 to 19in. and i just took some maf readings, and i get 5.6g/s at idle and 159g/s at wot...converted its 21 lb/min whichever is easier..is that a normal reading?
  9. #29 Re: KR Question??
    Outer Space
    Quote Originally Posted by iluvbst View Post
    If you 18 -19* it doesnt sound like a vac leak to me. Possibly just a whack tune IMO. If it was me.... I would unplug the battery for like 30 mins... then plug it back in. This will force the PCM to relearn the fuel trims.... which could take several med-long drives.
  10. #30 Re: KR Question??
    Quote Originally Posted by CTKGP09 View Post
    ecu=pcm for these cars (Performance Control Module) just for future reference
    I lol'd....
    its POWERTRAIN control module.
  11. #31 Re: KR Question??
    kissimmee,fl
    ^^ lol i know, i didnt bother to say anything...didnt want to sound like a dick...so this pcm has to be unplugged for 30min?? well battery i mean..
  12. #32 Re: KR Question??
    yeah, then drive it for a while
  13. #33 Re: KR Question??
    kissimmee,fl
    can i leave it unpluged overnight? then drive it in the morning..or it has to be exactly 30mins?
  14. #34 Re: KR Question??
    you can do the overnight thing.
    Just dont forget else you'll think your car is dead haha.
  15. #35 Re: KR Question??
    kissimmee,fl
    ok heard lol, should i do any wot pass in this relearn process?
  16. #36 Re: KR Question??
    not really.
    The car doesnt learn fuel trims at WOT IIRC
  17. #37 Re: KR Question??
    kissimmee,fl
    ok and should i have unplugged the the positive or negitive terminal?..i know some cars are diffrent about that...
  18. #38 Re: KR Question??
    either?
    Depends if the car was wired with conventional or modern electricity.
    i'm not kidding about that either.
  19. #39 Re: KR Question??
    it doesnt matter, however, youre 'supposed' to disconnect the negative terminal when disconnecting batteries.
  20. #40 Re: KR Question??
    kissimmee,fl
    how the hell would i know that! lol
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
