i need to bump this post. I just bought the car from hawkeye, wanting to fix it. The fuel pump isn't priming at all, i click the key and i don't hear anything. If the car sits all night i can start the car. As soon as i shut it off, no restart. I checked the fuel pump relay's, oddly enough there isn't a relay for the high speed mode, there aren't any connections for it at all. The relay doesn't seem to be the problem since i swapped one in from my working 99. I get voltage to the fuel pump, the battery was dying so i only got 2.5 volts out of one of the plugs on the pigtail. Also I did a fuel pump re-wire (zzp kit)
Any ideas? Im almost thinking the whole fuel pump assembly needs replacement. Could a bad cps be causing the fuel pump to not prime?
