Thread: 03 GP 3100 sfi fuel problem?
Results 1 to 13 of 13
  1. #1 03 GP 3100 sfi fuel problem?
    Kentucky
    I have a 2003 GP with a 3100 sfi and am having a start problem.
    I have replaced the fuel filter.
    I ran a pressure test (while running ) was 50 psi.
    When I turn the car off it leaks down.
    I was told it could be a fuel pressure regulator ?
    When I turn the key on I can hear the fuel pump building pressure..
    It only does this now and then but starting to be more frequent ..
    Thank you for any help.
  2. #2 Re: 03 GP 3100 sfi fuel problem?
    Charles City, IA
    It could be the regulator, but more than likely it is the fuel pump.
    SMGPFC Two Nipple General
  3. #3 Re: 03 GP 3100 sfi fuel problem?
    Kentucky
    Sounds like what ever it is im gonna need a sack full of money
  4. #4 Re: 03 GP 3100 sfi fuel problem?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    wait...ur describing to me a good working system
  5. #5 Re: 03 GP 3100 sfi fuel problem?
    Feb 2010
    somewhere cold
    what do u believe is wrong with this?
  6. #6 Re: 03 GP 3100 sfi fuel problem?
    Charles City, IA
    They should not leak down.
  7. #7 Re: 03 GP 3100 sfi fuel problem?
    GT Level Member sic6's Avatar
    san marcos, tx
    Your check valve in the fuel pump is leaking down.Thats what is causing it to leak back to the tank when the engine is off.
  8. #8 Re: 03 GP 3100 sfi fuel problem?
    Kentucky
    I have has someone tell me to start the car .
    Pull off the vacum line off the pressure regulator and look for bubbles to come out of the regulator.. Well ive done that and nothing?
    What do you guys think now??
    I have been told that 50 lbs was ok and not the fuel pump..
    Thanks you for the help.
  9. #9 Re: 03 GP 3100 sfi fuel problem?
    Feb 2010
    somewhere cold
    ur pump is fine...i put in a brand new gm pump last year and it does the same thing and has never given me a problem in 25000 miles of driving. please describe the start problem so we dont have to guess your symptoms and maybe we may have a better solution then the fuel system.
  10. #10 Re: 03 GP 3100 sfi fuel problem?
    Kentucky
    This problem only happens now and then?
    What it does when you get in and try to start it (after a drive ) it acts like it doesnt get fuel?
    You have to crank and crank to where the battery is almost dead before it will fire.
    There is no smell of gas like it flooded.
    Sometimes you can hold the gas pedal to the floor and crank it will fire.
    It seems to have plenty of spark?
    Thank you for the help.
  11. #11 Re: 03 GP 3100 sfi fuel problem?
    Feb 2010
    somewhere cold
    what u need to do is check your fuel pressure when your trying to start it and it wont start..if u still see 40+ then your looking in the wrong place if it dips then we have a problem houston but before a bunch of speculation occurs get us this info
  12. #12 Re: 03 GP 3100 sfi fuel problem?
    Feb 2010
    somewhere cold
    and describe to me "seems to have plenty of spark" what are you basing this off of?
  13. #13 Re: 03 GP 3100 sfi fuel problem?
    Kentucky
    As far as spark I have pulled each plug wire and cranked to see if theres spark. This is the only way I can for now. I am going to start driving it to work and just carry my pressure gauge with me just in case it decides to do it.
    Hey thank you for helping out.
    Scott
  1. Another Fuel Gauge Problem
    By SilverGT in forum General Tech Discussion
    Last Post: 06-13-2012, 09:45 PM
  2. Fuel pickup problem
    By g8rmark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 07:32 AM
  3. 2001 Grand Prix SE w/3100-- A/c problem, clutch not engaging.
    By Bartbk02 in forum Introductions/Noob Questions
    Last Post: 07-07-2009, 12:50 PM
  4. Fuel Pump Problem
    By ericrluoma in forum General Tech Discussion
    Last Post: 04-13-2009, 01:19 PM
  5. 97 gtp fuel gauge problem???
    By iwinagn in forum General Tech Discussion
    Last Post: 07-28-2008, 01:32 PM
