Thread: 1997 GTP help.
Results 1 to 6 of 6
  1. #1 1997 GTP help.
    SE Level Member Hawkeye1975's Avatar
    nj
    I have a 97 GTP with about 130,000, stock car except for random tech downtube, kn filter and upgraded plug wires. I've owned the car for over 5 years now with only minor issues, but recently have had stalling and restarting issues, the car has no engine light or stored codes, fuel pressure is in the mid 50 range at the rail. Early this year I replaced the fuel pump and fuel filter.
    So two week ago, my car stalled while I was driving and would not restart. The engine would turnover and sometimes it would just stumble for afew seconds. This was after a long drive on a hot day. So at that point I'm thinking I have a fuel delivery issue. The next day the car started and ran fine. I replaced the fuel filter thinking there was some debris inside. Also a new fuel pump resitor and relay after I knew the problem was still there.
    Since that first time I have had restarting issues once the car is warmed up and I just stop for afew minutes, come back and it wont start. Usally I get get it started 10 minutes later once its cooled down alittle.
    So, I trying to narrow down the testing/part replacement and try to get a good idea what going on. Thanks.
  2. #2 Re: 1997 GTP help.
    PA
    Sounds like a bad CPS.
    2001 GSE
  3. #3 Re: 1997 GTP help.
    nj
    Quote Originally Posted by Zef_66 View Post
    I have considered the crank and cam postion sensors, just surprised I'm not getting any engine light and code.
  4. #4 Re: 1997 GTP help.
    PA
    Quote Originally Posted by Hawkeye1975 View Post
    Those sensors typically will not set an engine code when bad.
    2001 GSE
  5. #5 Re: 1997 GTP help.
    nj
    Well I recently got in a minor accident and have decided to sell the car as-is. Looks like I can't sell it on this forum, until I get 20 posts.
    I do have it listed locally on Ebay. Let me know if anyone has interest. Thanks.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170537525281&viewitem= &sspagename=STRK%3AMESELX%3AIT
  6. #6 Re: 1997 GTP help.
    Jersey
    i need to bump this post. I just bought the car from hawkeye, wanting to fix it. The fuel pump isn't priming at all, i click the key and i don't hear anything. If the car sits all night i can start the car. As soon as i shut it off, no restart. I checked the fuel pump relay's, oddly enough there isn't a relay for the high speed mode, there aren't any connections for it at all. The relay doesn't seem to be the problem since i swapped one in from my working 99. I get voltage to the fuel pump, the battery was dying so i only got 2.5 volts out of one of the plugs on the pigtail. Also I did a fuel pump re-wire (zzp kit)
    Any ideas? Im almost thinking the whole fuel pump assembly needs replacement. Could a bad cps be causing the fuel pump to not prime?
    16' wrx sti- stock
  1. 1997 gtp
    By zildjian102 in forum Introductions/Noob Questions
    Last Post: 05-09-2010, 01:21 AM
  2. 1997
    By chrisxcountry1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-29-2009, 09:59 PM
  3. 1997 SE 3.8 with really bad mileage, what can i do?
    By x1lightning in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-08-2009, 11:30 AM
