Thread: Tried changing the S/C oil...
Results 1 to 14 of 14
  1. #1 Tried changing the S/C oil...
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Went out popped the hood and saw something that just pissed me off... The bolt on the top of the S/c was stripped... Took it to the stealership thinking they could just get it off and replace the bolt... They told me they are not supposed to service S/cers and that I'd have to pay them 100 buck just to replace the oil and that the bolt wouldnt be changed... So I'm fuming anything I can do for this?
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Tried changing the S/C oil...
  3. #3 Re: Tried changing the S/C oil...
    West Side Michigan
    You can go to home depot and get a screw remover kit thing. It taps into a striped screw and removes it slowly. It's like a drill bit but it removes screws. Then I don't know what you can do to replace it.. go try and match it at homedepot?
  4. #4 Re: Tried changing the S/C oil...
    drill and tap the hole then get it out and order a replacement from ZZP or some other vendor
  5. #5 Re: Tried changing the S/C oil...
    you dont need to put the same thing in it, just find the right thread and put a metric bolt in it and be done.
  6. #6 Re: Tried changing the S/C oil...
    Jul 2010
    Michigan
    Does anyone happen to know the size bolt that it is? Btw I really hate the dealerships... buy a car from them and they d onothing for you... no loyalty anymore like my dad always used to talk about
    2005 GTP Grey
  7. #7 Re: Tried changing the S/C oil...
    West Side Michigan
    if you go to home depot they have a little display where you can try and thread the bolt into various sizes. That way you can find out the type of thread, and then they can help you with the length. Then you should be all set!!
  8. #8 Re: Tried changing the S/C oil...
    Jul 2010
    Michigan
    Alright thanks I will have to do this this weekend. I appreciate it guys. I managed it on my old Bonnie so I was very pissed when I saw this on the GP
    2005 GTP Grey
  9. #9 Re: Tried changing the S/C oil...
    If you place the thread of the plug parallel to that of a bolt the threads will fit perfectly if the thread is the same.
  10. #10 Re: Tried changing the S/C oil...
    if theres room use a grinder with a thin blade and cut a grove it, use a screwdriver to remove it.i;ve done this a boat load of times, sometimes you don't have a choice, ya got to do what ya got to do.
  11. #11 Re: Tried changing the S/C oil...
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    i was hoping after the ... in the title you were gonna say you got it on your taint and it burns.
  12. #12 Re: Tried changing the S/C oil...
    Jersey
    i got a new oil bolt from the dealer.
    I was pissed when one of my snout bolts broke off, got it out 5 hours later, then found that the dealer doesn't sell a replacement
    16' wrx sti- stock
  13. #13 Re: Tried changing the S/C oil...
    Jul 2010
    Michigan
    Quote Originally Posted by noreasonwhyy View Post
    Whattttt???? LMAO
    2005 GTP Grey
  14. #14 Re: Tried changing the S/C oil...
    There was a thread about just that a little while ago...
  1. Changing SC Oil.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-03-2010, 11:58 PM
  2. Changing The Set-Up Of My Gun / Gun Pictures... Obviously
    Last Post: 10-11-2009, 09:21 PM
  3. Changing Thermostat
    By Connors33 in forum General Tech Discussion
    Last Post: 07-06-2009, 11:31 PM
  4. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
