Wow, you are just focused on those coils. Listen, if a coil was bad it would throw you a misfire code. And that would give you check engine light, but since you don’t have a light it really can’t be a coil. But hey I have been wrong before. If it makes you feel better go buy ONE coil (~$40) and a cheap multi-meter (~$15). Also, there are a million of these cars finding a coil won’t be hard, don’t sweat it being in stock. You only need one, because for all 3 to be bad would be like winning the lottery two weeks in a row. If you buy the meter get back to me and I’ll take the time to write out the test, but don’t worry it is easy to test them.
If I was there looking at your car this is what I would do. #1 check the fuel pressure at key on, and at idle. #2 Clean the throttle body. Most ppl totally neglect the throttle body maintenance because the car is fuel injected right!?!What happens is carbon (and crud) build up on the outlet of the throttle causing it to stick. This is also very easy to clean. Just unplug the throttle body cable. Spray in carb cleaner using your finger to hold open the throttle plate. Clean the walls and plate thoroughly, and that will eliminate this area as a potential cause.
