Thread: Exhaust/MSD ignition coils; to do or not to do?
Results 1 to 18 of 18
  1. #1 Exhaust/MSD ignition coils; to do or not to do?
    SE Level Member Blacknight02GT's Avatar
    Feb 2009
    Buffalo,NY
    I've got an 02 GT that i've had for the last few years.. and every so often I add a new mod. I get bored if i'm not always doing something, but yet i don't have alot of time or the know how to attempt a successful top swap. All i have now is a CAI and will definitely be getting the PCM tuned either by overkill or Intense over the winter. Now, I was looking online at the Grand Prix store and was thinking about the SLP catback exhaust and MSD ignition coils. Should i do a U bend delete (find somebody with a welder) and get the catback; or should i just get the high flow cat converter they have with the U bend delete already taken care of and not worry about the cat back? What will give me better performance out of a N/A car? Also are the MSD's any good? Thanks.
    2002 Grand Prix GT (K&N + Ram Air = BEAST)
  2. #2 Re: Exhaust/MSD ignition coils; to do or not to do?
    Charles City, IA
    coils are just for looks. The down pipe would be your best bet.
    SMGPFC Two Nipple General
  3. #3 Re: Exhaust/MSD ignition coils; to do or not to do?
    Wausau, WI
    ^^^^as stated above by 01 GTP....he speaketh the truth. The MSD coils are actually rated lower than stock as I have read. Get a downpipe with or without cat, and this includes the u bend delete in it.
  4. #4 Re: Exhaust/MSD ignition coils; to do or not to do?
    Feb 2009
    Buffalo,NY
    Quote Originally Posted by Liquifire View Post
    Okay, looks like I will be avoiding the Coil packs thanks for the heads up on that one. Where do I get a downpipe from that includes the u bend delete?
  5. #5 Re: Exhaust/MSD ignition coils; to do or not to do?
    Oct 2008
    Northern Illinois
    I've heard the MSD coils are actually worse than stock, so no on that. The GTP coil packs would be a minor upgrade but other than that just leave it alone, unless you're pushing like 400 whp ignition mods really don't make any noticeable difference. I've heard the SLP catback sounds sick, but that's about all it does, there's no performance gain from a catback. If I were you I'd get a 2.5" catted Downpipe for the exhaust which will show some good performance gain, and that will also get rid of your U-bend and include a high-flow cat like you were thinking of getting. Then if you want it to sound good pick up that catback system.
  6. #6 Re: Exhaust/MSD ignition coils; to do or not to do?
    Donating Users Uno99's Avatar
    Appleton, Wi
    Please dont get the coil packs. Mine went bad as well as 2 other local GP guys in my area. My stockers are back on my ride now.
    Get the u-bend outta there. Like others have said get a DP. The stock cat-back flow pretty good IMO. I say get a 2.5 or 3" DP fo sho.
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  7. #7 Re: Exhaust/MSD ignition coils; to do or not to do?
    Wausau, WI
    as stated above, the stock cat back flows good until 350 WHP, so there will be no performance improvements for that mod. Forget the catbacks unless you are doing it for sound. If you want it just to sound good, save some money and just order some borla mufflers to put on it. That will improve sound and save you money. Personally, I would go with the 3" DP and that will give you a little bit of a deeper tone as well, along with performance gains....
  8. #8 Re: Exhaust/MSD ignition coils; to do or not to do?
    Oct 2008
    Northern Illinois
    I'd go 2.5 on a lightly modded GT, but everyones got their own opinion on that bI guess.
  9. #9 Re: Exhaust/MSD ignition coils; to do or not to do?
    Wausau, WI
    are there any plans for an HV3 or to mod beyond the downpipe ever? If so, get the 3" IMO.......if you stop with the DP and aren't going to touch it, toss up...depends on preference as the 2.5 is barely bigger than stock, and pretty much just deletes the u bend. Kind of a waste IMO. If you want a deeper tone, or to flow better on higher rpms's get the 3" IMO...
  10. #10 Re: Exhaust/MSD ignition coils; to do or not to do?
    Feb 2009
    Buffalo,NY
    Alright, thanks for all the great advice. No, I don't really have any other plans or an HV3 planned for the future, but it looks like I should still get the 3" downpipe anyway huh? Where do I buy this thing from anyway?
  11. #11 Re: Exhaust/MSD ignition coils; to do or not to do?
    MO
    ZZP has it ZZ Performance
    <brandonl2000> LMAO D!!
  12. #12 Re: Exhaust/MSD ignition coils; to do or not to do?
    Wausau, WI
    yes, get it from zzp. They have the best pricing on downpipes by far, and have a very good quality part here whether you go catless, stainless, or aluminized.
  13. #13 Re: Exhaust/MSD ignition coils; to do or not to do?
    Appleton, Wi
    How much cash do you have to work with?
  14. #14 Re: Exhaust/MSD ignition coils; to do or not to do?
    Feb 2009
    Buffalo,NY
    Quote Originally Posted by Uno99 View Post
    I'll check out zzp then for sure. Ah, well i'd like to not spend over 400 on this endeavor but it doesn't really matter I have enough money free for anything not ridiculously overpriced.
  15. #15 Re: Exhaust/MSD ignition coils; to do or not to do?
    Jersey
    3" d/p on an N/A car is just silly, get a 2.5". Fwiw, im still running stock gt coil packs
    16' wrx sti- stock
  16. #16 Re: Exhaust/MSD ignition coils; to do or not to do?
    Feb 2009
    Buffalo,NY
    Quote Originally Posted by 99prixgt View Post
    What's the major differences between them, Like why would it be silly on N/A car?
  17. #17 Re: Exhaust/MSD ignition coils; to do or not to do?
    Banned - Busted For Scamming
    Feb 2009
    There is no difference in gt/gtp coil packs.
  18. #18 Re: Exhaust/MSD ignition coils; to do or not to do?
    Appleton, Wi
    If you wanna go on the cheap end for the u-bend delete you could to this check out the link below however I recommend the DP
    3800 V6 Exhaust Products and Accessories - Pontiac Grand Prix GTP, Chevy Monte Carlo / Impala SS, Buick Regal GS - Thrasher Engineered Performance
  1. MSD Coils???
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2009, 07:41 PM
  2. Exhaust & Coils
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2008, 05:09 PM
  3. MSD Ignition Coils
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2008, 10:18 AM
