Thread: headers question please help
Results 1 to 20 of 21
mcsddd headers question please help 08-07-2010, 08:15 AM
gtpinsc Re: headers question please... 08-07-2010, 08:27 AM
Colossus Re: headers question please... 08-07-2010, 09:47 AM
gtpinsc Re: headers question please... 08-07-2010, 09:49 AM
Rocket468 Re: headers question please... 08-07-2010, 11:31 AM
mcsddd Re: headers question please... 08-07-2010, 03:02 PM
Joe m Re: headers question please... 08-07-2010, 03:01 PM
Colossus Re: headers question please... 08-07-2010, 04:04 PM
AmericanRiceEater Re: headers question please... 08-07-2010, 04:30 PM
Colossus Re: headers question please... 08-08-2010, 12:05 AM
gtpinsc Re: headers question please... 08-08-2010, 06:22 AM
91z Re: headers question please... 08-08-2010, 10:01 AM
gtpinsc Re: headers question please... 08-08-2010, 10:29 AM
Colossus Re: headers question please... 08-08-2010, 11:14 AM
gtpinsc Re: headers question please... 08-08-2010, 11:31 AM
mcsddd Re: headers question please... 08-08-2010, 11:45 AM
matt5112 Re: headers question please... 08-08-2010, 11:51 AM
mcsddd Re: headers question please... 08-08-2010, 05:24 PM
gtpinsc Re: headers question please... 08-08-2010, 05:42 PM
91z Re: headers question please... 08-08-2010, 10:10 PM
Colossus Re: headers question please... 08-08-2010, 11:24 PM
  1. #1 headers question please help
    the desert
    on the safely modding thread it says if you get headers you dont have to worry about the ubend/downpipe or powerlog. are you guys talking about these headers?
    PACESETTER Header PONTIAC Grand Prix GTP 97-03 70-1205: eBay Motors (item 300434309520 end time Sep-02-10 09:04:49 PDT)
    or these headers?
    97-03 PONTIAC GRAND PRIX SUPERCHARGER RACING HEADER 6pc: eBay Motors (item 170469647572 end time Sep-03-10 17:40:53 PDT)
    or both will do the same thing?
  2. #2 Re: headers question please help
    Jul 2008
    sumter,south carolina
    all headers have the real "u bend" taken out. speed daddy headers have a bend in the downpipe but its not a U BEND. its more of a clearance issue going over speed bumps... other than a few scuffs on my speed daddys there isnt a problem with it. get the speed daddy headers. pace crusters require welding.
    02 GTP with mods 05 GP for DD
  3. #3 Re: headers question please help
    Windsor (ON) Canada
    We should all be commision from Speed Daddy....
    They're cheap, but not cheaply made, have them too....work great.
  4. #4 Re: headers question please help
    Jul 2008
    i know right.... i bet they have sold hundreds of sets cuz of GPF
  5. #5 Re: headers question please help
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    I like my togs
    My EX wifes other car is a broom.
  6. #6 Re: headers question please help
    the desert
    thank you everyone but i have one more question is there any how to's on installing sd headers?
    i found this one
    http://www.grandprixforums.net/speed...eup-32920.html
    but any others floating around? i like using many different sources lol
  7. #7 Re: headers question please help
    GT Level Member Joe m's Avatar
    mesa,az
    i love my ssac's besides the dip in the downpipe. makes me hit bumps and speedbumps.
    mods - ssac headers,custom intake,ported blower, cut lim for i/c, al104's,180*t-stat,3.4.
  8. #8 Re: headers question please help
    Windsor (ON) Canada
    With a quick glance, that looks like a good thread.
    I did mine with VERY little experience, my biggest issue was the rust welded down pipe to cat back bolts that required a dremel cutting wheels and carbid drill bit, hopefully you'll have more luck.
    Simply:
    -KEEP your stock head gaskets (Do not use the ones with the kit)
    -You will probably break the cross over bolts (oh well)
    -Best to get (2) 3" and (2) 2.25" band clamps, got mine at Napa (as appose to the horseshoe clamps in the kit) (unless your getting things welded)
    -Copper RTV is your best friend (use it on at all of the connection points)
    -For the rear manifold, pull the engine forward and pull your Transmission tube, (I tried "bending" it, didnt help, and you don't have to go as far as removing the rear vaulve cover like some people talk about) I removed my throttle body too, and slid the rear manifold back there ...... eventually.
    -You'll need an O2 extension for the first sensor on the rear manifold (got mine from ZZP)
    -Patience.
    -If I missed anything, Im sure ppl will chime in
    Good luck.
    ps....Thanks for using the search option!!
  9. #9 Re: headers question please help
    GT Level Member AmericanRiceEater's Avatar
    New York
    You'll want a new interlocking flex pipe from ebay or zzp. 3" x 6".
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  10. #10 Re: headers question please help
    Windsor (ON) Canada
    Quote Originally Posted by AmericanRiceEater View Post
    ?? Never had an issue with mine...by the way of your sig, doesnt look like you have the SD headers, there really hasn't been an issue with this interlocking flex leaking.
  11. #11 Re: headers question please help
    Jul 2008
    u should also either do a EGR delete or make sure u seal up EGR hole really good with RTV..me and several other ppl had a leak there.
  12. #12 Re: headers question please help
    Mn
    Would the speed daddys also work on an 04?
  13. #13 Re: headers question please help
    Jul 2008
    yes they would... they arent advertised to work... but several members here have installed them with no major probs.
  14. #14 Re: headers question please help
    Windsor (ON) Canada
    EGR delete
    took maybe an hour, most of the time spent on making the block off plates.
  15. #15 Re: headers question please help
    Jul 2008
    or u can just cut the tubes on EGR and take off the mounting plates... copper RTV a nickel to one and a penny to the other and works just as well.
  16. #16 Re: headers question please help
    the desert
    thanks for all the tips everyone but can we get more pictures and more tips on installing the headers lol im still kind of confused like the 3 inch straight pipe where does that go? and the 2.5 pipe where does that go?
  17. #17 Re: headers question please help
    ebay pace****ters might not fit period.
    And pace ****ters are not worth the money considering the speed daddy's work with less issues.
  18. #18 Re: headers question please help
    the desert
    im just wondering but why should i do the egr delete?
  19. #19 Re: headers question please help
    Jul 2008
    cuz its more than likely gonna leak there.
  20. #20 Re: headers question please help
    Mn
    Thanks for the info on the 04 fitting. Other than the block off plate what is needed for the computer to do the egr delete?
  1. SD Headers install question
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2010, 12:51 PM
  2. Question about headers.
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 06-28-2010, 10:38 PM
  3. Question regarding headers
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2010, 03:47 PM
  4. headers question on '04
    By hinkaj02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:45 PM
