Thread: Plog
Results 1 to 8 of 8
  1. #1 Plog
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Gonna be installing a Plog this week and was just curious, the dip stick look like it needs to be moved to install it. I havent looked a whole lot into it yet. Any suggestions?
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: Plog
    GT Level Member Going Too Phast's Avatar
    Some people have installed the plog without removing the dipstick. I don't know why you wouldn't, takes all of 30 seconds and putting it back is it pretty easy. Just use a flashlight if you need to see the hole better when you reinstall the dipstick tube.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  3. #3 Re: Plog
    Feb 2008
    Nashville
    It just pull out?
  4. #4 Re: Plog
    Oklahoma
    Pretty much, there is a bolt that holds it on one of the exhaust manifold studs, but you take that off and it will just pull out. A little twist and pull at the same time and it should come out.
  5. #5 Re: Plog
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Make sure you check the condition of the o-ring after you remove the dipstick. The key to reistalling is watching where it comes out. The first time I didn't pay attention and it took me a bit to spot the hole when reinstalling.
    fwiw I've installed a plog on two different cars and can't imagine doing it without remoing the dipstick.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Plog
    Feb 2008
    Nashville
    Thanks guys
  7. #7 Re: Plog
    Feb 2008
    Nashville
    Do I need to torque bolts down on the Plog a certain amount or just hand tight?
  8. #8 Re: Plog
    St Louis MO
    Quote Originally Posted by JCG's-GTP View Post
    Heres the spec's http://www.grandprixforums.net/torqu...ifications.php. I just tightened them with the ratchet very tight.
    2010 Camaro SS LS3
  1. Plog vs PEM or Ported TB vs HVTB
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 02:00 PM
  2. Pics of Plog plz :-)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2008, 09:13 PM
