Thread: Plog
Results 1 to 8 of 8
  1. #1 Re: Plog
    Oklahoma
    Pretty much, there is a bolt that holds it on one of the exhaust manifold studs, but you take that off and it will just pull out. A little twist and pull at the same time and it should come out.
  2. #2 Re: Plog
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Make sure you check the condition of the o-ring after you remove the dipstick. The key to reistalling is watching where it comes out. The first time I didn't pay attention and it took me a bit to spot the hole when reinstalling.
    fwiw I've installed a plog on two different cars and can't imagine doing it without remoing the dipstick.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Plog
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Thanks guys
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  4. #4 Re: Plog
    Feb 2008
    Nashville
    Do I need to torque bolts down on the Plog a certain amount or just hand tight?
  5. #5 Re: Plog
    St Louis MO
    Quote Originally Posted by JCG's-GTP View Post
    Heres the spec's http://www.grandprixforums.net/torqu...ifications.php. I just tightened them with the ratchet very tight.
    2010 Camaro SS LS3
  1. Plog vs PEM or Ported TB vs HVTB
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 02:00 PM
  2. Pics of Plog plz :-)
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2008, 09:13 PM
