Thread: supercharger gen q's
Results 1 to 6 of 6
  1. #1 supercharger gen q's
    TDCRacing
    Guest
    Ok so i always hear about people swapping for gen5's ect so i have a cupple questions.....
    The gen 3 s/c came on the gen 3 engines correct?
    The gen 5 s/c came on the 04+ gtp engines correct?
    Is there a gen 4 somewhere??
    What is better about the gen 5 to make people do swaps from the gen 3's?
    I have always wondered the above but just got some time to ask...TIA
  2. #2 Re: supercharger gen q's
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    Not sure what a "Gen 3" engine is. If you mean Series III, then no. The Gen 3 M90 came on Series II 3800s.
    It came on any Supercharged Series III 3800. Not just Grand Prixs, and not just GTPs (GTP became GT in the newer GPs I think).
    Eaton did make Gen 4 blowers, but they weren't used on the 3800s. Gen 5 was out by the time GM made the Series III.
    The casing design is more efficient, as well as a four-lobe rotor design as opposed to the three-lobe design in the Gen 3 M90. This helps smooth the air pulses, making it even more efficient and easier to choke down by the motor. I think there is more twist in the lobes as well down the length of the rotor. Eaton has a lot of info about it on their site. Best place to get the info is from the maker.
    2009 Subaru Impreza WRX STI
  3. #3 Re: supercharger gen q's
    TDCRacing
    Guest
    ok so i have a gen 5 blower on my series III 99 gtp 3800 then right? and the same exact blower is on the 04+ right?
  4. #4 Re: supercharger gen q's
    Barksdale AFB, LA
    The 99GTP has a Series II 3800...
    If you swapped for a L32 (Series III Supercharged) then yes you have a Gen 5.
  5. #5 Re: supercharger gen q's
    TDCRacing
    Guest
    my bad so i got the series 2 witht the gen 3
  6. #6 Re: supercharger gen q's
    Barksdale AFB, LA
    Yep.
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  3. supercharger coupler
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2008, 04:41 PM
  4. American Supercharger MPS
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2008, 09:44 PM
