Thread: weird power window problem
Results 1 to 9 of 9
  1. #1 Re: weird power window problem
    Jul 2010
    Kentucky
    I had the same problem on my wires 97 GTP. Only hers was the drivers side front window. The problem I found on hers was that a brown wire on the back of the drivers side switch was loose. You couldn't tell by looking at it but when you wiggled the connector the window would roll up and down. The first place I would look is on this switch since it controls all of the windows. You should be able to pull the switch out without taking the door panel off. Good luck.
  2. #2 Re: weird power window problem
    Jul 2010
    Outside ATL
    if the plugs are the same--try one of the back window switches on the driver side front to troubleshoot. That seems like the easiest way other than jumping it.
  3. #3 Re: weird power window problem
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by TheBeastGTP View Post
    This. All the window switches are the same except for the driver's auto down one.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  4. #4 Re: weird power window problem
    SE Level Member Kstuck's Avatar
    Jul 2010
    Grand Blanc, MI
    Quote Originally Posted by SUpercharggme View Post
    This happened to me when I first got my car, drove me nuts until I took the connector out and fiddled with it.
  5. #5 Re: weird power window problem
    Donating Users Warbeaver's Avatar
    St. Louis
    thats a good idea. i'll try that.
    heres my experience yesterday:
    i took off the pasenger panel and i took a test light to the plug going into the motor. Theres 2 wires for it (1 only works when the window goes up and the other will only work if the window goes down) so it looks like its getting power. However, that test light i was using was grounded and i just think it tests to see if an electrical current is flowing. guy at shop said that it could be pinched ground wires in the door jams but i looked at all of those.
    so, i put a remanufactured motor in the car yesterday (new from store) and just plugged it in to see if the gear would turn. It did nothing. So i dont think its the motor, unless i got a bad motor from the store.... i have 2 newer switches coming in teh mail. if that doesnt fix it, i dont know what to do next...
  1. weird transmission problem?
    By stevenk8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 12:14 AM
  2. Really weird problem!
    By pyccke87 in forum General Tech Discussion
    Last Post: 10-03-2009, 10:22 PM
  3. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  4. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
  5. Weird Trans problem
    By 04CompG in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2009, 01:27 PM
