Thread: rich idle, lean when high rpm and knock?
Results 1 to 7 of 7
  1. #1 rich idle, lean when high rpm and knock?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    a friend of mine has a series 2 3800 and he is running -16 at idle and as soon as he passes 300rpm he goes +16 lean and hits over 8 on knock...what can cause this?
  2. #2 Re: rich idle, lean when high rpm and knock?
    whats he got done to the car. Mods??
  3. #3 Re: rich idle, lean when high rpm and knock?
    Feb 2010
    somewhere cold
    nothing she is stock just bought her yesterday oh and its a 2000
  4. #4 Re: rich idle, lean when high rpm and knock?
    Feb 2010
    somewhere cold
    checked fuel pressure and all is normal there
  5. #5 Re: rich idle, lean when high rpm and knock?
    Pennsylvania
    check plug gap.
  6. #6 Re: rich idle, lean when high rpm and knock?
    Bastard Reptile's Avatar
    Kansas City, MO
    If it's going that lean, and knocking that much, it's probably lean.
    check the MAF, TPS or the O2 to make sure they aren't on the fritz?
  7. #7 Re: rich idle, lean when high rpm and knock?
    Feb 2010
    somewhere cold
    Quote Originally Posted by Reptile View Post
    these were my original thoughts so i did check them and all seemed fine to me as to why i posted..figured it was a gt thing as ive never owned one. just for ****s and giggles ill swap the maf and map just to make sure but they show fine on the laptop
  1. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  2. Rich vs Lean
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 05-23-2010, 11:39 AM
  3. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
