Thread: Help with fuel sensor???
Results 1 to 8 of 8
  1. #1 Help with fuel sensor???
    GTX Level Member nikkigpgt00's Avatar
    MI
    My gas gauge is not working properly! In fact I ran out of gas on the side of the expressway a few days ago. It went from saying I had a 1/4 tank to empty within minutes. Will go from full to half, back to full then down to empty, fluctuates really bad!
    I have done some searching and did find some info but I'm not really sure what exactly I need to replace. The fuel pump? The fuel sensor? My boyfriend said he would fix it for me if I could figure out what needs fixed and find something showing how to do so. Any help would be great!!!!
  2. #2 Re: Help with fuel sensor???
    MI
    No one????
  3. #3 Re: Help with fuel sensor???
    Charles City, IA
    The fuel level sensor on the side of the pump is going to ****. Most gms do this.
    SMGPFC Two Nipple General
  4. #4 Re: Help with fuel sensor???
    MI
    So how can I fix it???
  5. #5 Re: Help with fuel sensor???
    Charles City, IA
    replace it
  6. #6 Re: Help with fuel sensor???
    GTP Level Member SuperSport's Avatar
    Michigan
    Go to GMpartsdirect.com and search for part number 89060197. It should be around 90 dollars. Once you get it, get into the backseat and open the pass thru. Pull up the carpet where the carpet meets the backseat. Remove the oval cover and youll be exposed to the top of the tank. Remove the snap ring or lock ring, unplug the 2 connectors, and pull the pump out. Unclip the float, unplug it, plug the new float on, and replace it all. Takes about 45 mins.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  7. #7 Re: Help with fuel sensor???
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    ^^ couldnt of said it better
  8. #8 Re: Help with fuel sensor???
    MI
    Awesome thanks! I just had to go through replacing my blower motor and resistor I'm hoping this won't be as difficult!
  1. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  2. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
