Go to GMpartsdirect.com and search for part number 89060197. It should be around 90 dollars. Once you get it, get into the backseat and open the pass thru. Pull up the carpet where the carpet meets the backseat. Remove the oval cover and youll be exposed to the top of the tank. Remove the snap ring or lock ring, unplug the 2 connectors, and pull the pump out. Unclip the float, unplug it, plug the new float on, and replace it all. Takes about 45 mins.
