Thread: Help with fuel sensor???
Results 1 to 8 of 8
  1. #1 Re: Help with fuel sensor???
    GTX Level Member nikkigpgt00's Avatar
    MI
    Go to GMpartsdirect.com and search for part number 89060197. It should be around 90 dollars. Once you get it, get into the backseat and open the pass thru. Pull up the carpet where the carpet meets the backseat. Remove the oval cover and youll be exposed to the top of the tank. Remove the snap ring or lock ring, unplug the 2 connectors, and pull the pump out. Unclip the float, unplug it, plug the new float on, and replace it all. Takes about 45 mins.
    Awesome thanks! I just had to go through replacing my blower motor and resistor I'm hoping this won't be as difficult!
  1. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  2. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
