it's directly behind your radio on the driver side. may be a little lower but you need to take off the kick panel and then a few dash pieces to get in there. do a search either here or google.
once you've got the motor off, you need to disassemble the motor and make note of which way the shaft from the blend door rotates when you move the cold/hot knob so you know which way to align the gears.
