Thread: Please help !!! Car won't turn !!!
Results 1 to 8 of 8
  1. #1 Please help !!! Car won't turn !!!
    SE Level Member PontiacGrandPrixGT's Avatar
    Jun 2010
    Newark , DE
    Hello
    I have read every possible tread in this forum and still no luck
    The car is 2002 GP GT
    The other day i went to the store and park the car. Turned it off and when i came back 30 min later, did not start.
    When i try to do it , i only hear a click from the inside, same thing if it is on park or neutral !!
    Replaced Neutral Safety switch .. no luck!
    Starter is good , because when i go underneath the car , it starts from there.
    However , there is no power coming to the purple starter wire
    PLEASE HELP !!!
    Last edited by PontiacGrandPrixGT; 08-23-2010 at 11:45 AM. Reason: missed something
  2. #2 Re: Please help !!! Car won't turn !!!
    You replace the PNP on the trans? I kinda thought a 2002 would have that inside the trans.
    My understanding of the internal PNP is the pcm then enables the start relay to fire the starter.
  3. #3 Re: Please help !!! Car won't turn !!!
    Charles City, IA
    could be an ignition switch start at the top of the circuit and work your way down untill you loose power.
    SMGPFC Two Nipple General
  4. #4 Re: Please help !!! Car won't turn !!!
    Jun 2010
    Newark , DE
    PNP switch... i guess you mean the neutral switch.. yes i have replaced it
    it is located on top of the transmission
    Well , i only the last thing to check is the ignition switch,but it is kind of hard to get it out. And i am not really sure after i get it out what to do and how to test it.
    Not sure if its the switch by itself or the wiring
    Any ideas or recommendations what to when i take it out?!?
    Thanks
  5. #5 Re: Please help !!! Car won't turn !!!
    Apr 2009
    stockton ca
    you dont have to take it out just get a wire diag for the circiut
  6. #6 Re: Please help !!! Car won't turn !!!
    Ohio
    did you try the simple comon fix or even checking it? the battery?
    00 GTP demodded and forsale
  7. #7 Re: Please help !!! Car won't turn !!!
    Jun 2010
    Newark , DE
    battery is good
  8. #8 Re: Please help !!! Car won't turn !!!
    Jun 2010
    Newark , DE
    i am really lost ! the wiring seems to be fine !! anybody else?
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Cant turn off car right away...
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 03-07-2010, 11:20 PM
  3. Cant turn key off sometimes?
    By PCweber in forum General Tech Discussion
    Last Post: 08-30-2009, 01:28 PM
  4. Key won't turn
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2009, 05:17 PM
  5. Turn a se into a gt/gtp
    By 99PHILLYGRANDPRIX in forum General Tech Discussion
    Last Post: 10-26-2008, 03:58 PM
