Quote Originally Posted by CMURDAx View Post
when i had this problem in my car a couple months back. we couldnt figure it out for the life of us. finally my dads buddy happened to look at my brake fluid level and that was it, the little bottle was empty, but my brakes still worked good. so just cause your brakes are working good dont mean theres enough fluid. double check and see if it went down any.
I will check the fluid level again. Maybe I might add just a little. If that doesn't work, then I'll pull the tires off and check the connectors on the rear ABS sensors.
Thanks for the info.
