Thread: ABS light and TC Off light On : (
Results 1 to 20 of 22
  1. #1 Re: ABS light and TC Off light On : (
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    when i had this problem in my car a couple months back. we couldnt figure it out for the life of us. finally my dads buddy happened to look at my brake fluid level and that was it, the little bottle was empty, but my brakes still worked good. so just cause your brakes are working good dont mean theres enough fluid. double check and see if it went down any.
  2. #2 Re: ABS light and TC Off light On : (
    Jul 2010
    Cumberland, RI
    Quote Originally Posted by CMURDAx View Post
    I will check the fluid level again. Maybe I might add just a little. If that doesn't work, then I'll pull the tires off and check the connectors on the rear ABS sensors.
    Thanks for the info.
  1. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
