Thread: ABS light and TC Off light On : (
Results 1 to 20 of 22
  1. #1 Re: ABS light and TC Off light On : (
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    My car has the ABS on and the Trac light on + the check tire pressure light. My tires are at their correct pressure so its just goofed up.
    on the other hand, I don't need the ABS.. But thats just me
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  2. #2 Re: ABS light and TC Off light On : (
    SE Level Member Beauty026201's Avatar
    Jun 2010
    Cape Cod, MA
    Quote Originally Posted by GrandPrixSE View Post
    My GP did that...wheel bearings on R front was the culprit for me.
  3. #3 Re: ABS light and TC Off light On : (
    Jul 2010
    Cumberland, RI
    My wife's 97 Grand Prix is doing the same thing. ABS light & TRAC light on. The only thing is that when the brakes are applied, the lights go off. I replaced the front hub assemblies back in March and everything has been fine since.
    The brake fluid level is OK, so I will check the ABS sensors in the rear and see what I find. The brakes work fine except for ABS light & TRAC lights comming on until you apply the brakes.The lights remain off until the next time they decide to come on. I expect to be replacing the rear ABS sensors.
    I don't understand why the lights go out when the brakes are applied.
    ANy advice would be appreciated.
  1. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
