Thread: should i give up
Results 1 to 19 of 19
  1. #1 should i give up
    SE Level Member GTPgurl's Avatar
    Jul 2010
    syracuse, ny
    so heres the prob got a v6 3800 gtp sc (not a mechanic) put in new: icm, coils, battery, alternator, pcv, plugs, wires, wheel barrings, a tie rod, all new brake stuff and im sure im forgetting a lot more also ses abs end low trac lights all always on low coolant light comes on and kinda flashes till i put more water in it (i know waters not the best idea) but pretty sure head gaskets blown (or cracked manifold) i have put so much money, time, blood, sweat, tears and more money into this really really pretty pain in the ass. i do not have money to even think about trying to buy or finance another car. should i give up on it and drive it till id dies and try to save 500 for a crapcar or keep fixin it? i do get a massive discount on parts my bf works at auto parts warehouse and he puts them in so i do not have to pay mechanics costs. please help i need input what do you think???
  2. #2 Re: should i give up
    Donating Users Ibwrong's Avatar
    Oklahoma City
    So tell us what its doing, the ABS and Trac Lights have nothing to do with it having a cracked manifold or head gaskets being blow... Describe what its doing that makes you think its the above mentioned items.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: should i give up
    Jul 2010
    syracuse, ny
    sorry just trying to remember everything that is wrong it knock when it is started does this for about 5-10 min then runs fine ont time the knocking wouldnt stop but i added lucas and now it just does it when it is started also occasionally it will misfire cyl 4 or6 and the whole car shakes but it stops and runs fine after its warmed up. also mysterious coolant loss but oil still look good. i want to know if you think it is worth having my bf do the head gaskets.
  4. #4 Re: should i give up
    Outer Space
    if your mysterious losing coolant, its most likely your LIM gasket.
    02 GTP 13.6 @ 100mph - SOLD
  5. #5 Re: should i give up
    Donating Users Warbeaver's Avatar
    St. Louis
    not sure what could be causing a misfire other than coolant possibly getting into the cylinders and fouling up the plugs (making the tips white). This is usually from bad head gasktets but i would think bad lim gaskets could do this as well?
    maybe clogged injectors?
    i'd check the plugs again. what kind you using? and what gap?
  6. #6 Re: should i give up
    Jul 2010
    syracuse, ny
    does anyone know how to tell the difference between blown head gasket and cracked intake manifold
  7. #7 Re: should i give up
    Compression test will show the blown head gasket whereas it'll test fine with a cracked LIM (assuming its your lower since i've never heard of a cracked blower case).
    Its probably your LIM gasket as we discussed in the chat.
  8. #8 Re: should i give up
    Jul 2010
    syracuse, ny
    matt thanks so much for the info do you think i should bother with the compression test or just replace the lim gasket (low on the $$) and do you think replacing the lim, changeing the oil and flushing the collant would make the engine ticking go away?? oh and warbeaver idk about the plugs ill find out and let you know,
  9. #9 Re: should i give up
    Outer Space
    See if your oil looks milky, or take of your oil cap and look on the inside of it....mine had yellow goo in it.
    When your LIM acts up, coolant mixes with oil.. making a goo..that can lead to engine fail.
    No need to a compression test if you have determined coolant is indeed in the oil.
  10. #10 Re: should i give up
    Jul 2010
    syracuse, ny
    oil seems fine a little crud on cap and dipstick but its deffinately not milky but i am slowly losing coolant with no visible leak
  11. #11 Re: should i give up
    Outer Space
    Then a pressure test might be the thing to do... let's see what the others say .. im sure someone else will chime in.
  12. #12 Re: should i give up
    the question is, what coolant are you running (colour) and how long has it been since the LIM gaskets have been changed and how long since the coolant has been flushed.
    Compression test is worth your time if you have someone with the equipment who can help or let you borrow their tools.
  13. #13 Re: should i give up
    Jul 2010
    syracuse, ny
    warbeaver i got bosch platinum plugs dont know the gap. matt i think its the orange coolant we usually use but just been adding water lately i dont have the money to keep dumping coolant down the drain. not gonna do the tests dont know anyone with the equipment. but this week we will be replacing both the upper and lower intake manifold gaskets also the valve cover gaskets and seals, going to flush the coolant and do oil change. and while it all apart we may be replacing a lifter that may be stuck. i really hope by the end of all this i still have a car. lol let you know how it goes. any more input always greatly appreciated thanks guys
  14. #14 Re: should i give up
    Jul 2010
    syracuse, ny
    by the way i have no idea how to thank you guys for the help. im still fairly new here. but thank you very much for all the input!!
  15. #15 Re: should i give up
    Jul 2010
    syracuse, ny
    sorry just thought of another question ... i got ses codes p0440 (evap emission control system malfunction) and a misfire code that switches from cyl 4(p0304) to cyl 6 (p0306) do you think those will go away after replacing all this stuff this week???
  16. #16 Re: should i give up
    evap code wont be solved by this and the misfires might if coolant was the issue but i highly doubt it.
    Get some non bosch plugs and see if the misfire goes away, if not, get some new wires.
  17. #17 Re: should i give up
    Jul 2010
    syracuse, ny
    ok ill try that too but i just did the new plugs and wires about 6 months ago should i get more new wires or just the plugs
  18. #18 Re: should i give up
    wait first
  19. #19 Re: should i give up
    Jul 2010
    syracuse, ny
    ok so replaced the upper and lower intake gaskets and the plugs, flushed the coolant and changed the oil. it still ticks but not as bad and not as long it stops before its warm. and i got the same codes back the misfire and evap emitions...so next project i guess will be replacing lifters, heads and valves. ahhhh any tips or advice very much appreciated
  1. Ok, i give, what is this?
    By TowerLadder43 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-30-2010, 02:51 AM
  2. Give this a try...
    By kjclawson in forum Off Topic Discussion
    Last Post: 03-05-2010, 02:31 PM
  3. 2002 Won't give my key back
    By BLOWN93LX in forum Introductions/Noob Questions
    Last Post: 07-31-2009, 09:05 AM
  4. Will you give this to my Daddy?
    By TMC in forum The Rant Forum
    Last Post: 05-09-2009, 09:55 PM
  5. This car will definitely give you wood!
    By Warhellride in forum Off Topic Discussion
    Last Post: 05-09-2008, 06:06 PM
