so you need to support the engine when you unhook the dogbones? my mounts are worn the engine has to much play in it for them to be goog
I have the WBS mounts... they work great and there's very minor vibrations. I'd get them over the Intense units as they look 100% like the same part (they have the same exact raised edges/pattern) and the WBS mounts are $30 less.
I twisted the old ones out with the bolt/nuts and then soaped up the new ones and whacked them in with a rubber mallet. The entire job took about 15 minutes... and no you don't need to support the motor, it's supported from underneath.
