i was driving down the highway the other day when suddenly my temp gauge starts going higher and higher, and overheats before i can get stopped. so i pull off at the next exit at a truck stop and see that the rad is completely dry. Fill it up with water, and i see it all leaking out of a small hole right by the fan. I've put a ton of stop leak through it, which works for a bit, but then starts leaking again. Im going to get a rad today and put it in...do you think the motor will still be fine, no warped/cracked heads, head gaskets etc.? ughhhh i hate this car sometimes
