Thread: Car gets too hot while in traffic
Results 1 to 20 of 27
  1. #1 Car gets too hot while in traffic
    dfw, tx
    Now that the summer months are here and it's up near 100* here in Dallas, my car is starting to have issues with running too hot.
    I have about a 45 minute drive from work to home. The car runs at a normal temp (the 180*-ish tick on the gauge) all the way until I get about a mile from my destination and get stopped up in traffic. Once I'm in it for about 5 minutes or so, the needle on the temp gauge goes up to the 210* mark on the gauge and you can tell the computer clicks over into safe mode or something... starts to idle down, the ac clicks off, will barely accelerate at all once you start trying to drive again, feels like the trans keeps shifting all around... All until I get rolling again and the temp drops below 210* and it drives like normal again until I have to stop again.
    The car has had a 160* thermostat in it for probably 10 years now, mostly water with the coolant and 2 bottles of Water Wetter. It's never had a problem until recently.
    Also I have a DHP reprogrammed computer I bought from the grandprixstore a couple years ago. I was wondering if the tune wasn't set up for the 160* thermostat if it would cause the car not to cool properly?
  2. #2 Re: Car gets too hot while in traffic
    Outer Space
    Check your fluid levels ...and change your thermostat first. To me, that is the cheapest thing to do. Mine rises like that in this hot weather too. But the highest I have seen so far is like 205*. I checked the fluids, and burped the coolant system (screw ontop of thermostat housing).. so far so good.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Car gets too hot while in traffic
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    do your cooling fans come on at all? if the pcm was not set up "properly" it would be set up to correspond with a 195 degree thermostat. even then it should never get up to 210. check the coolant, and check and make sure the fans are coming on. also, your aftermarket thermostat is 10 years old, theres a good chance it could be failing
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Car gets too hot while in traffic
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    Quote Originally Posted by Jakegday View Post
    couldn't have said it better.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  5. #5 Re: Car gets too hot while in traffic
    dfw, tx
    Quote Originally Posted by Lawngoose View Post
    I topped off the fluid levels a couple weeks ago, but didn't bleed the system out. Didn't know it was needed on these cars.
    I do have a new 180* thermostat I'm going to install this weekend and flush the coolant system out.
    Anyone got a link to how to bleed the air out of the system?
    I never pull over on the shoulder to check the fans coming on, but I know once I get to wherever I'm going and turn the car off, the fans are still on for a few minutes after I turn the car off, so I'd assume they're blowing while the car is running.
    I did drive around yesterday until I got into traffic and the temp gauge started creeping up, so I clicked off the a/c and rolled the windows down and the temp came back down to a normal level, though I was sweating my ass off...LOL
  6. #6 Re: Car gets too hot while in traffic
    Outer Space
    Quote Originally Posted by 99gtxws6 View Post
    Just fill it up, let it run to operating temp... then unscrew it (I think its a 7mm) just enough to let some fluid/air come out of it then tighten .
    If you want to be anal about it.. do it a few times.
  7. #7 Re: Car gets too hot while in traffic
    dfw, tx
    Sounds easy enough. My old 96 Cobra used to be a ***** about getting air in the cooling system and overheating and it had to be filled and bled out a certain way to get all the air bubbles out. Guess it's the same with this, though it's only been a problem recently.
    Also, the inside of the overflow tank looks like it's got a bunch of dirt or sand coated on the inside of it. Maybe a cooling system flush is in order...
  8. #8 Re: Car gets too hot while in traffic
    my car hit 220 according to my aeroforce before the fans kicked in and pulled it down to 195.
    Now its basically stuck between 180 and 190 due to stricter fan settings.
  9. #9 Re: Car gets too hot while in traffic
    FYI, 210* is not even close to being too hot for a car. at 210* for the coolant i bet you are running more efficiently than at 195*.
  10. #10 Re: Car gets too hot while in traffic
    dfw, tx
    Once the temp on the gauge reads < 210* then the car switched into what I was told "safe mode" so it won't overheat and tear something up by trying to keep driving it too hard until it cools off.
    Makes it difficult to drive while it's in safe mode but once i'm driving again and air is moving through the radiator it starts to cool back down and clicks back out of safe mode and drives with full power again.
  11. #11 Re: Car gets too hot while in traffic
    Nov 2008
    Fremont Nebraska
    true story
  12. #12 Re: Car gets too hot while in traffic
    i have no clue what youre talking about and ive seen the ECU file..are we talking tranny temp? cause coolant gets to 210* all the time.
  13. #13 Re: Car gets too hot while in traffic
    Apr 2009
    stockton ca
    seriously coolent is safe up til around 230-50 due to boilout basically depends what your antifreeze water mix is
  14. #14 Re: Car gets too hot while in traffic
    Donating Users Viperkill97's Avatar
    Arizona
    really sound like your fans are going bad.
    Life goes by so fast, so why drive slow.
  15. #15 Re: Car gets too hot while in traffic
    Apr 2009
    stockton ca
    could also be a clog in the rad or bent fins but doesnt sound that bad
  16. #16 Re: Car gets too hot while in traffic
    Brewcity, WI
    I'd replace thermostat and flush/clean/flush/etc. I had a similar prob, but not near as hot. Drained dex out, flushed 2 times, ran a cleaner, flushed 2 more times and filled with prestone. Now my car never even gets to 195ish anymore, stays around 180 or below no matter what I do.
    Self-denied SMGPFC member #1
    SEARCH works!
  17. #17 Re: Car gets too hot while in traffic
    dfw, tx
    You have no clue about what part?
    Quote Originally Posted by TorqueAutoMotiv View Post
    Last time I filled the system, I used one gallon of antifreeze, two bottles of Water Wetter, then topped the rest off with water. I've only ever added water to the system when it needed it.
    The coolant might be safe up to 250* but the car starts to shut down once the needle on the water temp gauge goes much higher than the 210* mark. So either the water temp gauge reads a lot lower than the actual water temp, or the computer has it programmed to cut power above 210*
    Quote Originally Posted by Viperkill97 View Post
    Checked the fans yesterday, both fans are on at idle and after shutting the car off. I can only assume they are both on while I'm driving too.
    Thinking a clogged radiator might be the culprit. Really need to do a flush out of the system and get my new thermostat installed.
    Quote Originally Posted by Pepino View Post
    That's the plan soon as I get time hopefully next week. Til then I'll just cut the a/c off when sitting so it doesn't run too hot.
  18. #18 Re: Car gets too hot while in traffic
    HUDSON
    My car (2000GTP) got one tick away from the red zone on the gauge sittinf through MCdonalds one day, the car ran no different than normal, but the gauge did go down as soon as I got out and back on the road, all it turned out to be was low on coolant. You computer must be programmed to do somthing when it get to that temo your saying, and really hot for a car engine is 230 and above, as long as you don't loose coolant, and have good antifreeze, all should be ok.
    Either your low on coolant and there is air in the system, or maybe there is a problem with you sensor.
    The thing about being low on coolant is that when the temp gauge go's up, it's reading the open air space around the sensor and not the actual water temp witch may be still just perfectly normal temp.
    Have you checked for any coolant leaks?
    DEan
  19. #19 Re: Car gets too hot while in traffic
    dfw, tx
    Quote Originally Posted by QUICKSILVER462 View Post
    DEan
    Not sure about the programming. That's just what I was told over on clubgp when asking about it having issues running last year while it was hot outside.
    And there's no leaks under the car or in the engine compartment that I can see. Unless it's leaking internally somehow, but the oil is still clean.
  20. #20 Re: Car gets too hot while in traffic
  1. stall on traffic ( low RPM ) and have hesitations
    By anxxus in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2010, 11:28 PM
  2. Car died in traffic, won't stay running.
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 10:28 PM
  3. dont do burnouts in traffic
    By blowfishRus6 in forum Off Topic Discussion
    Last Post: 09-10-2008, 07:40 PM
  4. Interesting article on Traffic and Driving
    Last Post: 07-08-2008, 10:07 PM
