Thread: Doing some maintenance
Results 1 to 12 of 12
GoldGTP Doing some maintenance 03-17-2011, 10:55 AM
BillBoost37 Re: Doing some maintenance 03-17-2011, 11:11 AM
GoldGTP Re: Doing some maintenance 03-17-2011, 11:15 AM
GoldGTP Re: Doing some maintenance 03-17-2011, 11:29 AM
Fivefingerdeathpunch Re: Doing some maintenance 03-17-2011, 11:32 AM
GoldGTP Re: Doing some maintenance 03-17-2011, 11:35 AM
codyAK Re: Doing some maintenance 03-17-2011, 11:39 AM
GoldGTP Re: Doing some maintenance 03-17-2011, 11:41 AM
Bio248 Re: Doing some maintenance 03-17-2011, 11:53 AM
GoldGTP Re: Doing some maintenance 03-17-2011, 12:01 PM
nascartech Re: Doing some maintenance 03-17-2011, 01:07 PM
GoldGTP Re: Doing some maintenance 03-17-2011, 01:39 PM
  1. #1 Doing some maintenance
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    After finding I had a crack in my rim and having it fixed, I noticed that my front end wobbles were not dampened any...
    So guessing the previous owner had hit a pot hole, or knocked it with a curb pulling in somewhere, I'm deciding on doing some front end repairs...
    I also had my ABS light come on recently, but I did a quickie check, and the ABS sensor wire was ripped out of the wheel bearing!!
    So after tooling around on ZZP and RockAutos' websites, I have come up with the following parts/repairs -
    ZZP -
    Supercharger Coupler
    VIN :
    Option 1:2 GM S/C Oil 8 oz.
    Option 2:none selected $44.98 $44.98
    Stage 1 axles
    VIN :
    Model:One pair of HD axles $174.99 $174.99
    Sub Total: $219.97 + Shipping
    RockAuto -
    2003 PONTIAC GRAND PRIX GTP 3.8L 231cid V6 FI Supercharged (1) OHV
    BOSCH Wire Set Part # 09457 $20.99
    Transmission ANCHOR Part # 2712 Hydraulic Mount Trans. $20.79
    Engine ANCHOR Part # 2796 Hydraulic Mount Front $26.79
    AUTOLITE Part # XP606 Xtreme Performance OE Style; Gap .060 $4.46 x6 = $26.76
    Axle Bearing and Hub Assembly TIMKEN Part # 513179 Includes ABS Sensor FrontB $89.79 x2 = $179.58
    DEEZA Part # PNB603 OE Type; Front Inner Tie Rod $6.62 x2 = $13.24
    CHASSIS Part # AXES3453 Front Outer Tie Rod $7.13 x2 = 14.26
    Total Shipped = $337.75
    I guess a question I would have is, how hard would it be to drop the tranny with the mounts and axles out of the way?
    Reason I ask is because I would love to get into the tranny just enough to get to the flexplate and change it out...
    I guess another question I would have is, what else would you do as far as other parts, suggestions on the repair, or what not to do.
    One last question would be, who wants to help!! $$$
    Thanks fellas, these forums have infinite wisdom!! (if you use the search box correctly)
  2. #2 Re: Doing some maintenance
    None of the stuff you have planned would make you get to the point of taking out the trans.
    However. If you pop the balljoints to do the axles, and have the trans drained ... pull the subframe out fo the way and the trans is about 15 more bolts to drop out.
  3. #3 Re: Doing some maintenance
    Sacramento, CA
    Thanks for the reply....
    So if I was to replace the control arms, it would make life easier in the way of tranny dropping?
    I need to purchase the FSM for this car.
  4. #4 Re: Doing some maintenance
    Sacramento, CA
    Oops, meant to put this in the supercharged section...
  5. #5 Re: Doing some maintenance
    why you buying stage 1 axles??
    just find some axle's at your local auto parts store with a lifetime warranty.
  6. #6 Re: Doing some maintenance
    Sacramento, CA
    I suppose I thought ZZP "stock" would be a nicer pair of axles?
    Thanks for the insight.
    Napa = $80 a pair
  7. #7 Re: Doing some maintenance
    Ocala, FL
    Quote Originally Posted by GoldGTP View Post
    Napa = $80 a pair
    I wouldnt buy them at napa either, parts store axles you will replace yearly.. Buy a good set from Morad.
  8. #8 Re: Doing some maintenance
    Sacramento, CA
    Quote Originally Posted by codyAK View Post
  9. #9 Re: Doing some maintenance
    the stage 1 axles are only nice because they have grease fittings on them, the stock ones dont.
  10. #10 Re: Doing some maintenance
    Sacramento, CA
    Grease fittings are always a good thing, right?
    Thanks for the reply and the move...
  11. #11 Re: Doing some maintenance
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    good parts list but i would ditch the hydraulic mounts and go with solid rubber dont go poly though or u will have vibration
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  12. #12 Re: Doing some maintenance
    Sacramento, CA
    The "Solid rubber" ones ZZP sells?
    Motor
    Trans
    I want to ensure there is NO added vibration with these...I tried a a few "solid dog-bones" on my wifes Cavalier, and the vibration was a no-go...
    The tranny one looks nice...
    Thanks for all the replys.
  1. car maintenance
    By cerick08GP in forum Off Topic Discussion
    Last Post: 11-29-2010, 02:33 AM
  2. maintenance fun
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-12-2010, 12:21 AM
  3. Time for car maintenance
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 04:35 PM
  4. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
  5. New GTP owner, what maintenance should I do?
    By xDetroitMetalx in forum General Tech Discussion
    Last Post: 01-17-2010, 04:26 PM
