This is SOO easy and should be a sticky, cause it seems to be a common problem that people hunt for fixes by replacing uneeded parts. What happens is the Fuel Pump Resistor that selects between the pump cycling in low and high speed takes a dump, and here is the quick fix that just fixed my car 5 minutes ago for a problem i couldn't figure out hooked up to a Genesys. It would run about 5 to 10 seconds and just die without hesitation. It started stalling randomly on the road then continued to just get worse. Follow this image i found on another forum to fix your stalling issue.![]()
