Thread: bought the wrong rear view mirror need help
Results 1 to 10 of 10
  1. #1 bought the wrong rear view mirror need help
    SE Level Member xsvtank's Avatar
    NJ
    okay so i bought a grand prix auto dim mirror and i realized the plug in the back is different from the one that was in the car. the old one had 3 prongs the new one has 7. my querstion is can i change the wire in the car to make it work? if so where can i get that plug.
    Thankyou
    Frank
  2. #2 Re: bought the wrong rear view mirror need help
    Nov 2008
    Chicago
    Ive found the hard way that its usually not worth the hassle. I got a supercharger off of a Regal for $18. I ended up spending way more than that to get it connected correctly
  3. #3 Re: bought the wrong rear view mirror need help
    Quote Originally Posted by FuglyGTP View Post
    Totally different situation.
  4. #4 Re: bought the wrong rear view mirror need help
    NJ
    i found a fellow board member that had an extra connecter ill make a judgement calll hopefully itle work
  5. #5 Re: bought the wrong rear view mirror need help
    Nov 2008
    Chicago
    It was a generalized statement with an example. Some things are easy, some things aren't
  6. #6 Re: bought the wrong rear view mirror need help
    Joliet, IL
    the wires should be the same color on both harnesses just match the 3.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  7. #7 Re: bought the wrong rear view mirror need help
    GT Level Member hourang's Avatar
    commerce, mi
    why even plug it in? who needs autodim anyway.
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  8. #8 Re: bought the wrong rear view mirror need help
    Nov 2008
    Chicago
    I hated autodim at first. Now I love it
  9. #9 Re: bought the wrong rear view mirror need help
    SE Level Member RustedOutBuick's Avatar
    Charlotte,NC
    I upgraded my mirror when it went bad. You need the plug for the new mirror, but you don't need to do any major wiring. The terminals for both mirrors are the same. If you use a little pin, you can release the wires from the 3 prong connector. Do the same for the 7 pin connector, then just push the 3 pins into the new 7 pin connector. It took me about 10 minutes start to finish to repin the new one.
  10. #10 Re: bought the wrong rear view mirror need help
    Feb 2010
    Pullman, WA
    Does anyone have one of these 7 pin connectors? I have the same situation and was wondering if anyone has one or knows where I can get one.
    Thanks.
  1. rear view mirror with on star
    By shawngtp in forum General Tech Discussion
    Last Post: 12-04-2009, 02:07 PM
  2. Rear View mirror tab
    By Toasty in forum General Tech Discussion
    Last Post: 02-17-2008, 12:48 AM
