Thread: Rear View Mirror Install & Wiring
Results 1 to 4 of 4
  1. #1 Rear View Mirror Install & Wiring
    Cambridge, Ontario Canada
    Picked up a rear view mirror with all the bells & whistles (onstar etc). Unfortunately, my car only has a 3 wire plug and the mirror has a 10 wire plug or something like that.
    Anyone have a wiring diagram so I can make it work?
    Does anyone have a pic of that mirror mounted on the windshield? My car is missing the mirror and nothing is mounted to the windshield - I think I might be missing a part with the mirror I got?
  2. #2 Re: Rear View Mirror Install & Wiring
    SE Level Member RideMr2's Avatar
    Memphis
    The autodimmer, and any accessory lights on the mirror should work when you find the power and ground leads.
    Onstar, a built in compass, good luck getting those to work properly.
    If your windshield is missing the metal clip for the mirror, then you will need to get a universal mirror kit from autozone, napa, etc.
    I would take the mirror to the store with you, to make sure it fits.
    For pictures;
    Google universal rear view mirror kit
  3. #3 Re: Rear View Mirror Install & Wiring
    Thanks man, does anyone know where the control unit is used to drive the compass function?
    Will try a wrecker for the mirror base before trying a universal
  4. #4 Re: Rear View Mirror Install & Wiring
    Feb 2010
    Pullman, WA
    Hey did you get this figured out? I'm in the same wiring predicament minus the onstar and compass. I now have the accessory lights auto tint mirror but only have the 3 wire plug and need the 7 pin connector.
    Thanks.
  1. rear view mirror with on star
    By shawngtp in forum General Tech Discussion
    Last Post: 12-04-2009, 02:07 PM
  2. Rear View mirror tab
    By Toasty in forum General Tech Discussion
    Last Post: 02-17-2008, 12:48 AM
