Thread: weird....
Results 1 to 4 of 4
  1. #1 weird....
    Joliet, IL
    so i had a silicone gasket i made for my gen v......well i tightened to torque specs and the sc pulley was completely binded.... couldnt spin....loosened the bolts and it spun....tightened again, no spin....took out sc gasket tightened the blower down and it spun freely.....must be that the thickness of the silicone didnt let the amount of torque be evenly distributed and was in a way warping/cocking the case? well ill just get a paper one fukk it! whats your input?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: weird....
    Banned - Busted For Scamming
    Feb 2009
    I usually go less torque on the silicone one, especially if you made it from silicone baking sheet. I do not recommend the baking sheet anymore, its thicker. I get the 1/32" silicone sheet it works better. I normally had good luck with 10 ft/lbs on the thicker one. Just tighten one bolt, check for spin freely, move on. Hope that helps.
  3. #3 Re: weird....
    Joliet, IL
    just tightened to 130 in/lbs on mine and it spins freely thanks alot i was too afraid it would be loose but its solid! thanks alot. spins freely now just got a vac leak.....could be my gaskets/ tb adapter plate tho....ill have to get some carb spray and find it.....
    00 Silvermist GTP
  4. #4 Re: weird....
    Joliet, IL
    prob just gonna get a paper one since i dont plan on taking it off anytime soon.
    00 Silvermist GTP
  1. weird GTP
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 09:51 PM
  2. WEiRD BUT TRUE
    By gptrell502 in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2008, 06:03 AM
  3. Weird problems
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2008, 08:21 PM
  4. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
