Thread: weird....
Results 1 to 4 of 4
Threaded View
  1. #3 Re: weird....
    Joliet, IL
    I usually go less torque on the silicone one, especially if you made it from silicone baking sheet. I do not recommend the baking sheet anymore, its thicker. I get the 1/32" silicone sheet it works better. I normally had good luck with 10 ft/lbs on the thicker one. Just tighten one bolt, check for spin freely, move on. Hope that helps.
    just tightened to 130 in/lbs on mine and it spins freely thanks alot i was too afraid it would be loose but its solid! thanks alot. spins freely now just got a vac leak.....could be my gaskets/ tb adapter plate tho....ill have to get some carb spray and find it.....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  1. weird GTP
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 09:51 PM
  2. WEiRD BUT TRUE
    By gptrell502 in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2008, 06:03 AM
  3. Weird problems
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2008, 08:21 PM
  4. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
  5. weird...
    Last Post: 10-15-2008, 10:56 PM
