Thread: light problem!!!!
Results 1 to 3 of 3
  1. #1 light problem!!!!
    TDCRacing
    Guest
    Friends car....gtp.....no dash illumination....The key chime is on (noise when you leave the lights on and open the door after taking the key out of the ignition.) even when the headlight switch is off and the fog lamps are turned off.The weird thing is that you can turn the headlights on via the headlamp switch and the headlights come on (but with no dash illumination..again dash ill. is compleatly gone at all times) and you can also turn the fog lights on at the same time...no fog lamp switch turns on and fog lights do not work...now when you switch it to high beam the fog lights turn on...suppose to be the other way around...I was thinking a bad headlamp switch.Anyone have any ideas?
  2. #2 Re: light problem!!!!
    Saraland Alabama
    sounds like a bad switch
  3. #3 Re: light problem!!!!
    GT Level Member BackInBlack's Avatar
    Vermont
    Bad or unplugged (partially) headlamp switch for sure.
    The GPs are long gone...
  1. 98 GP GT with a PO442 code and light on.
    By Fritcr in forum General Tech Discussion
    Last Post: 11-17-2011, 06:39 AM
  2. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  3. help... my ses light is on
    By kingd44 in forum General Tech Discussion
    Last Post: 03-07-2008, 09:45 PM
  4. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
