Thread: Headlights
Results 1 to 4 of 4
  1. #1 Headlights
    Apr 2008
    A week after i bought my car my passenger side headlight went out. So i changed it and now there is this big gap. Anyone know what how to fix it?
  2. #2 Re: Headlights
    GT Level Member BackInBlack's Avatar
    Vermont
    Most likely one or more of the flat tabs on the back of the assembly is not in place. Take the capsule back out and try again...
    The GPs are long gone...
  3. #3 Re: Headlights
    Apr 2008
    I have tried everything. I put the tabs in and out and when i put the right tab in the slot its supposed to go i cant even put the bolt back into the left side. I sat there for probably almost an hour tring to figure it out but i cant.
  4. #4 Re: Headlights
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    My only guess as well would be to make sure that both tabs on that headlight are in the slots all the way and properly. Also make sure there are no plugs or wires in the way anywhere. If you simply pulled the headlight, replaced the bulb, and re-installed it I can think of no reason why it would not be the same as before.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  1. Headlights and taillights!
    By Kyle73044 in forum General Tech Discussion
    Last Post: 03-24-2008, 09:14 PM
  2. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
  3. WTF on the headlights
    By sra_chipmunk in forum General Tech Discussion
    Last Post: 01-06-2008, 11:20 PM
