Thread: Popping the hood without the cable.
Results 1 to 8 of 8
  1. #1 Popping the hood without the cable.
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Say that the hood cable were broken/disconnected...how would you go about getting the hood open?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  2. #2 Re: Popping the hood without the cable.
    Oklahoma
    A sledge hammer.
    Sorry, had to. The fact is Im not really sure. You may be able to drop out the lower air dam and get up in there to the hood latch but Im not sure. I know this has been discussed before so maybe someone will stop in here and give you some assistance.
  3. #3 Re: Popping the hood without the cable.
    Saraland Alabama
    I pulled a grill out, and popped mine at the latch there is a little ring there you can get a screwdriver on
  4. #4 Re: Popping the hood without the cable.
    Waynesboro, PA
    Quote Originally Posted by archemedes View Post
    Do you remember which grill? Or any description of what the "ring looks like? Thanks, I am hoping this is less painful than I imagine it.
  5. #5 Re: Popping the hood without the cable.
    Saraland Alabama
    either grill and the ring is just a 1/4 inch piece that the cable goes into, very easy (when I did it the alarm was set and it didn't go off until the plunger activated it)
  6. #6 Re: Popping the hood without the cable.
    I live here. UR LOSN's Avatar
    Rockford, IL
    97/98 did not have the vent tubes.... so you were able to reach your finger in under the latch system and move the latch mechanism over to where the hood would pop. (very bottom)
    on the newer models...I am not sure if you are able to get to it from the bottom of the car. or if your able to move the plastic vent tube out of the way on either side...you would be able to get to the bottom of the latch.
  7. #7 Re: Popping the hood without the cable.
    Saraland Alabama
    Quote Originally Posted by UR LOSN View Post
    that could explain it (mine is an early '97)
  8. #8 Re: Popping the hood without the cable.
    Waynesboro, PA
    To update, I did get the hood open. I pulled both of the grills. I went in the passenger side grill with a screwdriver, then fed it across to the other side. I used my right hand to align the screwdriver with the latch, then pushed the screwdriver and popped the hood. It could have been a lot worse! The latch is towards the front, so if you have the snorkels you will need to run your hand/screwdriver as far forward as you can, which is actually the back of the snorkel.
  1. Converting stock hood to "40th Anniversary" hood w/heat extractors[*]
    By Quicksilver_GP in forum How To Write-Ups/Tech Tips
    Last Post: 08-28-2013, 09:12 PM
  2. Speakers Loud Popping
    By GreenNirvana101 in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2008, 10:32 AM
  3. Whats with all these new GP forums popping up?
    By Fish in forum Off Topic Discussion
    Last Post: 12-22-2007, 03:44 PM
