Thread: Android = Aeroforce
Results 1 to 20 of 393
  1. #1 Re: Android = Aeroforce
    GT Level Member 04boostedindyss's Avatar
    May 2011
    boynton beach florida
    Sweet time to get the adapter I guess, which one seems to be the most commonly used
    E85, Gen V, Xp, Supporting mods, crap tune!
  2. #2 Re: Android = Aeroforce
    In a house
    Wait until a couple of people who already have the adapters have seen it working - I've only seen it from logfiles at the moment (so it appears to work) but I need someone with 1.4.66 to test where they *know* they have a value other than '0' for knock or can compare against another device
  3. #3 Re: Android = Aeroforce
    Colorado
    I know I have 4* of knock at WOT near redline with a Tech2 (GM's scantool). Ive never used a scangauge but a buddy at work has an older one he wants to bring in for me to play with.
    I just bought a Bracketron window mount for my CLiQ2. Makes my distracted driving much safer.
    I updated Torque today and re-added the PID's and took a drive on the Interstate. Torque now shows alot of data for several new PIDs like misfire count, evap and EGR data.
    KR now reads 5.1* at WOT anywhere above 5k rpm. One time it did spike to 6.6* when I snapped the thottle shut from about 70% throttle. It felt pretty accurate and definatley a huge improvement.
    It feels right but the formula could be a little off still. Its hard to tell without running a tech2 and torque side by side. I wonder if I could splice another DLC in the glovebox for my OBDlink. Any objections?
    Any ideas on what I could check or verifiy to make sure were on the right track before I put headers on?
  4. #4 Re: Android = Aeroforce
    In a house
    That's brilliant news! Sounds like the PID is now working and pulling valid data from the ECU!
    The formula should be correct, though checking would be good - the main point is that KR now appears to be being pulled okay so a simple formula change (if it is indeed required) shouldn't be a problem
    Thanks to you, and to ssjon, as well as others for sending debugging info and persevering whilst we get it working!
  5. #5 Re: Android = Aeroforce
    SE Level Member GoldenBoyGTP's Avatar
    US
    Seems to be working for me too. Got around .3 degrees at WOT with headers, CAI, and a few other small things on the stock pulley. So I guess that sounds about right. Hopefully someone can verify with another gauge. Let us know what you find, GTPZero.
    Thanks again, Ian. You're awesome for working with us and coming up with a solution. Gonna head over to the market and give Torque a good rating. I'll be spreading this thing as much as I can.
  1. aeroforce trade?
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2009, 12:55 PM
  2. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  3. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
