That's brilliant news! Sounds like the PID is now working and pulling valid data from the ECU!
The formula should be correct, though checking would be good - the main point is that KR now appears to be being pulled okay so a simple formula change (if it is indeed required) shouldn't be a problem
Thanks to you, and to ssjon, as well as others for sending debugging info and persevering whilst we get it working!
