Thread: Bad Engine Mounts
Results 1 to 10 of 10
  1. #1 Bad Engine Mounts
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Hey,
    Is there a good way to test if an engine mount needs to be replaced?
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  2. #2 Re: Bad Engine Mounts
    Largo, Florida, United States
    Drop the subframe
    Mine was sitting in a pool of Oil rubber was pretty much ALL gone.
    150$ replacement part from dealer or ZZP
  3. #3 Re: Bad Engine Mounts
    if you rev the car and your motor hits the firewall, replace them.
  4. #4 Re: Bad Engine Mounts
    South Jordan, UT
    I was doing a brake bleed the other day and had the hood open while I was torquing the pass front wheel. When the desired torque was about met, the engine would actually lean forward in the compartment like it wanted to hit the radiator! No clue if that is normal or if my top front mounts are toast (I don't see rips or anything)...
  5. #5 Re: Bad Engine Mounts
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    A visual inspection of the top mounts will tell you if they are toast. Keep in mind though, the top factory mounts are quite soft. I would suggest some mounts from 3800performance.com
    As far as the lower mounts are concerned... the engine mount seems to go quicker than the tranny mount. I knew mine was shot when I couldn't fit the larger PF-47 oil filter on the oil filter neck. The engine was actually sitting too far back!
    For all your 3800 needs:
  6. #6 Re: Bad Engine Mounts
    South Jordan, UT
    Quote Originally Posted by copgtp View Post
    That's really helpful info, thank you! When I was watching the top mounts flex while I was torquing the tire I knew those things had to be soft to be acting like that.
    I get this random clunking and I think it might be a motor mount. I've replaced the front struts and mounts and have inspected the front end a hundred times and can't figure out where it's coming from.
    When you are visually inspecting the top mounts, what exactly are you looking for?
    Your sig pic is sick BTW. Probably one of the best I've seen - I love it.
  7. #7 Re: Bad Engine Mounts
    Orange County, NY
    Unfortunately, I can't take credit for the sig, but thanks for the compliment.
    When you visually inspect the mounts, look for obvious signs of rubber cracking and general fatigue. How many miles on the stock mounts? You could always "flip the mounts". there is a writeup in the how-to section. This is a quick and simple way firm up the mount. I'd say if you are close to or around 100K mark, it's definitely time to swap them out for either new OEM mounts, or more likely some solid mounts from 3800 performance.
  8. #8 Re: Bad Engine Mounts
    South Jordan, UT
    They have 140K on them so I'm probably very due for an upgrade.
  9. #9 Re: Bad Engine Mounts
    Nov 2009
    Grand haven
    Stick your hand down by the crank pully and see if there is hyd oil sitting down there. It will feel like cottage cheese.
  10. #10 Re: Bad Engine Mounts
    South Jordan, UT
    Quote Originally Posted by shawngtp View Post
    You wouldn't mind taking a pic for me would you? I'm not sure exactly what I'd be looking for.
    I have talked to a few people who really don't like all the vibration poly mounts cause. Does anyone know of any mounts that are maybe a step up from OEM but not quite as firm as poly mounts?
    I'm probably going to try rotating the upper mounts and replacing the lowers.
  1. Symptoms of bad lower tranny/engine mounts
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2010, 03:40 PM
  2. Engine mounts?
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2010, 05:39 PM
  3. Autozone SOLID engine and trans mounts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 08-17-2009, 08:19 PM
  4. Painting my engine mounts today!!
    By kjclawson in forum Visual/Body Modifications
    Last Post: 08-16-2009, 10:53 PM
  5. engine mounts?
    By elusive racing in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2009, 10:44 PM
