Thread: Could THIS Be Causing All of the Engine Fires?
Results 1 to 20 of 53
  1. #1 Re: Could THIS Be Causing All of the Engine Fires?
    Ocala, FL
    Man, about a year ago today I started smelling fuel and found a leak at the disconnect.
    I could not locate o-rings anywhere at all, no luck whatsoever.
    I ended up buying a kit at harbor freight of lots of random sizes, and ended up finding the right sizes in there.
    It was a huge pain to get them out, and even worse to get them in.. but I did it.
  2. #2 Re: Could THIS Be Causing All of the Engine Fires?
    Oreillys sells the injector o rings as a pack of 12 believe they are from BWD if you people really insist I could find a part number.
  1. Heavy stutter under boost, but no mis-fires
    By 007 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 12:46 AM
  2. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  3. 97 fires but wont run.
    By clh97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2009, 10:08 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. Hub Assembly causing thunk?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 03-28-2008, 07:36 PM
