I have a 97 supercharged grand prix which has been stalling since 4/1. brought it to 4 different people - no one can figure it out. one place says it's losing spark but can't figure out where from.
Not the crankshaft sensor.
Fixed the fuel pump assembly/fuel filter
Fixed the ignition switch
Has anyone had a similar problem? this is what it does:
Starts up. Sometimes, you can drive it all day shutting it off and on with no problem. Then, while driving, all of the lights come on and the car stalls out - the battery doesn't die. when i turn the car over, it tries SO hard to start but just won't get that little "oomph" to make the car starts. one time, it started right back up...but that only happened that once. usually it takes 15mins to an hour to start.
