Quote Originally Posted by BDEGhost View Post
The connector is the one in your picture with the pink wire on the right.
The screws are security torx (I forget which size). You need a torx screwdriver or bit with a hole in the middle of it. Or, you can also use a dremel bit and ground away the pin in the middle of the head of the torx screw.
Thank you!! I have to see if my brother has a torx screwdriver for me. I'll report back.
