Thread: help me break 13's :/
Results 1 to 20 of 74
  1. #1 Re: help me break 13's :/
    Jul 2008
    nj
    What is not listed on his mods is a TEP trans with hard parts. I run stock pressures and I assume he should too. I will not know until I am in the car
    IMO...it is terrible. The base pe is set about right and then you look at the pe vs time table. He is commanding about 10.7 at the shift points. The pcm commands an additional 5* timing at 10.7 and then they took out timing in the good spark. Basically the tune was not thought all the way through which makes it terrible.
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  2. #2 Re: help me break 13's :/
    GTP Level Member
    Nov 2008
    MA
    looking forward to seeing what he runs now with a squared away tune
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  3. #3 Re: help me break 13's :/
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Damojo2003 View Post
    ehh.. If the trans is built, you want it shifting as fast and firm as it can during WOT. That means taking the shift pressures in the upper cells to 96 and shift times to .01. There are a lot of guys that like to run this way and so do I on cars. But it's really up to the one tuning it.
  4. #4 Re: help me break 13's :/
    Quote Originally Posted by FoSHO99 View Post
    I agree, but even when we installed them here, Dave specifically recommended keeping the line pressure stock because of how rought it would be...we had Brian's at 100% all the time and it would bark the tires at half throttle or even a little less. That's why I say don't mess with that there...but then again, to each their own...like you said at end.
  1. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  2. Break n oil
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-13-2009, 11:27 PM
  3. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
  4. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
