Thread: Ventilation problem
Results 1 to 16 of 16
  1. #1 Re: Ventilation problem
    Donating Users Viperkill97's Avatar
    Arizona
    so no other ideas.
    Life goes by so fast, so why drive slow.
  2. #2 Re: Ventilation problem
    Arizona
    Since the air blows out of all holes when the air is turned on, I am going to rip the dash apart tomorrow and see if the mechanism that controls where the air goes is bad or see if there is a fuse somewhere.
    What do you guys think?
  3. #3 Re: Ventilation problem
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    check ur vacuum line next to your battery its a small black plastic line alota times they come apart or break it starts by the battery and runs up then along fire wall
  4. #4 Re: Ventilation problem
    Arizona
    Quote Originally Posted by imdaman3 View Post
    check ur vacuum line next to your battery its a small black plastic line alota times they come apart or break it stars by the battery and run up then along fire wall
    its broken in half, is that what is causeing my problem.
  5. #5 Re: Ventilation problem
    Feb 2010
    ohio
    yes go to a parts store and get a rubber vacuum hose that will fit it put it back together and ur done, fixed
  6. #6 Re: Ventilation problem
    Arizona
    Thank you so much!!!!
  7. #7 Re: Ventilation problem
    Feb 2010
    ohio
    no problem
  8. #8 Re: Ventilation problem
    May 2012
    Jacksonville, Fl
    YOU are most certainly THE MAN! I was having the same problem, read your recommendation, found the problem and it is now fixed! Thank YOU!
  1. crankcase ventilation valve?
    By jmanners in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2009, 08:54 PM
  2. problem up top
    By 2000gtp1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 01:00 AM
  3. Anyone else have this problem?
    By PMave in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2009, 08:09 PM
  4. car problem....
    By hdc80 in forum General Tech Discussion
    Last Post: 08-27-2009, 07:38 AM
  5. How do i fix this problem?
    By thenervemann in forum General Tech Discussion
    Last Post: 11-01-2008, 01:49 PM
