Thread: High Pitched Whine noise when I press on the gas
Results 1 to 9 of 9
  1. #1 High Pitched Whine noise when I press on the gas
    Northwest Missouri
    my 2004 Grand Prix is making a high pitched whine noise when i press on the gas. It sounds like an R/C car. Any ideas?
    Ohio
    Could be alternator
  3. #3 Re: High Pitched Whine noise when I press on the gas
    transmission or alternator is my guess.
  4. #4 Re: High Pitched Whine noise when I press on the gas
    Minnesota
    Is your car supercharged? lol
  5. #5 Re: High Pitched Whine noise when I press on the gas
    Nov 2011
    Michigan
    use a stethoscope and start checking bearings, that would be my first step
  6. #6 Re: High Pitched Whine noise when I press on the gas
    new britain, ct
    it might even be your Power steering pump.
    check to see if you are low on power steering fluid.
    my car was low on PS fluid and was making a whine noise, saw it was low, added more, whine was gone and it hasnt returned.
    and if your PS levels are fine, its probably not that lol
    07 Black GXP.
  7. #7 Re: High Pitched Whine noise when I press on the gas
    Jul 2012
    My girl friends literally bought a grand prix GT2 yesterday (04) and It makes the same whine your talking about. It sounds like its freakin' supercharged. Also when the car is at a stop and you move whe wheel the powersteering makes a howling noise. So like ctracer said it might be the PS pump.
  8. #8 Re: High Pitched Whine noise when I press on the gas
    SE Level Member Storm Smith's Avatar
    Mar 2012
    Arkansas
    I have a 2000 Grand Prix that makes the same noise. Where is the power steering pump on it?
  9. #9 Re: High Pitched Whine noise when I press on the gas
    St. Louis
    Locate the alternator, then look way down underneath it. You can run your hand along the firewall and get to the cap. Will need a long funnel to fill/top off.
  1. High Pitched Horn Problem
    By Hippo Machine in forum General Tech Discussion
    Last Post: 11-26-2011, 10:24 AM
  2. High pitched hum and vibrating sounds?
    By SomeDudeAtHome in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2011, 05:38 PM
  3. High pitched whine
    By penguinknot in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 07:34 PM
  4. High pitched noise coming from dash?
    By Gortox454 in forum General Tech Discussion
    Last Post: 08-14-2010, 08:48 AM
  5. high pitched whine??
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 03:37 PM
