Thread: car problem....
Results 1 to 12 of 12
  1. #1 car problem....
    SE Level Member hdc80's Avatar
    iowa
    when i am going down the road my car jerks like u are drivin a standard....and it sometimes does not want to shift gears or it feels like the gear slips after i am going down the road i have taken it to a shop an they insist nothing is wrong but it still does it any ideas why??
  2. #2 Re: car problem....
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Does it jerk like this when it shifts or is it doing it at other times?
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: car problem....
    Wausau, WI
    more information please or just take it to another different shop for a second opinion.....
  4. #4 Re: car problem....
    iowa
    it jerks after i have shifted. when i put it drive or reverse and i take off it will jerk and then sometimes a few minutes later it jerks
  5. #5 Re: car problem....
    Wausau, WI
    sounds like your tranny is slipping and then jerking into gear.........are your tranny fluid levels good? When was the last time you had a tranny pan drop and filter change? If your levels are good and your filter is relatively new your tranny is probably on its way out.......... What year make model and miles do you have?
    Let us know what you have
  6. #6 Re: car problem....
    iowa
    it's a 2007 grand prix i believe 58,000mi yea the levels are good.
  7. #7 Re: car problem....
    iowa
    Quote Originally Posted by hdc80 View Post
    i was wrong it has 45,000mi. im sure the filter was changed
  8. #8 Re: car problem....
    At 45,000 most haven't considered a trans service yet. Please double check your receipts to ensure it was serviced.
  9. #9 Re: car problem....
    Wausau, WI
    so has the filter ever been changed? If not, get it changed ASAP.......
  10. #10 Re: car problem....
    Destroys cars izup69's Avatar
    Iowa
    yeh gl with that i have a 06 and ive had 2 trany's put in it so far and the 3rd one is on its way out the first one went out a 32k nd one at about 45k and now its got over 99k on it almost to 100k dose it still slip after its warmed up or just when u first start it up
  11. #11 Re: car problem....
    iowa
    it does it off and on sometimes it will right after i put it in gear and other times a lil ways down the road.yea my husband checks all that but it never happens when he drives it of course
  12. #12 Re: car problem....
    Wausau, WI
    get the filter changed now before it is too late unless you have already done so within the last five to ten thousand miles.
  1. Hello and a problem
    By Syerix in forum General Tech Discussion
    Last Post: 04-09-2009, 12:57 PM
  2. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
  3. Help Problem Please Look!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 12:22 AM
  4. 97 gp one problem after another
    By vermsta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2008, 08:44 PM
  5. Another HUD problem
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 03-10-2008, 05:51 PM
