Quote Originally Posted by jaetawright View Post
Bump for this question as it is a project that I would like to undertake as well. I have a 08, non-GXP. From what I can tell only the GXP's had the fog/turn signal lights. There is a 4 wire plug that includes an un-used purple wire. I assume that the purple wire goes to the fog light control. In my fuse block under the hood, fuse #7 (10 amps) says fog lights, and there should be a wire that interfaces withe the computer to turn the fogs on and off. Which wire is it? I have tried tracking it down with a multimeter, and was only able to disconnect my hi-beams.
Like the OP, I am not really interested in modding, rather would like to use the cars existing wiring to do the job. I know the wires are there, just dont know which ones to use, ore what signal to give them (+12 or ground). Any help would be appreciated.
Thanks,
Jon
while the gxps do have fogs im not looking for that cause to run gxp fogs on my car id prolly have to change wiring and replace the bumper but my year 06 the gts and gtp came with a lense that was part turn signal and part fog light mine is just a 3157 turn sig/park lamp i want the 898 fogs as well im just wondering if i can cut the headlight wire buy the 898 fog connectors new lenses and wire it str8 to my headlamps so when i turn the switch for the head light my fogs will come on to im tryin to do it the easiest way i was just gonna use heat shrink on the wires after i splice the 898 pig tails in place i just need to know b4 i buy the lenses and stuff if that will work
