Thread: Airbag Light
Results 1 to 12 of 12
  1. #1 Airbag Light
    SE Level Member djwags's Avatar
    May 2011
    Allentown
    Ok so I love my GP, but I'm forced to face the facts that it is not in the shape it once was. My airbag light is on/ has been on for a little while. Specifically it will the light will come on, it will flash a few times, and then just stay on.
    1: Does this denote what is wrong with the airbag, or is that the general "something is wrong with your airbag" reaction (e.g. clock spring, something else)?
    2: Inspection is quickly approaching and I'm on the extremely tight college budget. A check for Ramen might bounce haha). Do I need to have this fixed before I take it in? Its an 02 if that makes a difference either way? Obviously I'm not thrilled to not have airbags, but will it pass?
    02 Grand Prix GT-gutted airbox, sway bar
  2. #2 Re: Airbag Light
    St. Louis
    Yes, when the light flashes and/or stays on there is an issue w/ the system. Have it scanned and see what the code(s) are.
    And I have a feeling that it will not pass safety that way. As soon as they see the light my bet is it will fail. At least it would here.
  3. #3 Re: Airbag Light
    GTP Level Member 1ATony's Avatar
    mass
    It could be the clockspring. If you have cruise control has it stopped working?
    Tony
    1aauto.com
    SALES 888-844-3393
    Shop Here For: Grand Prix Parts
  4. #4 Re: Airbag Light
    May 2011
    Allentown
    ill check the cruise control today. I drove home from college yesterday and the light was doing all sorts of stuff. IT was off for a while, then flashed almost the rest of the whole way home. Any ideas?
  5. #5 Re: Airbag Light
    under the driver seat is wires, look for the yellow one, see if its unplugged, or unplug it and make sure its not corroded, and under the front pass seat, under the rug, is a air bag module that is screwed to the floor, it gets corroded where its mounted to the floor and is the ground for it, remove it, sand it and the floor clean, some of the units come apart, if yours does, open it and clean the corrosion off the inside too.
    if these things dont help its best to just have it scanned so you not throwing money at the wrong parts, listed above is a free check and may help or may not.
    im having the same problem, bought the car with every light on the dash lit up, im down to a air bag light, and im going to have to take it in to be scanned as well one of these days. my radio controls on the wheel dont work, but my cruise control works, so my car may need a clock spring, as ive found out through my own research.
    and i actually just passed inspection with the air bag light lit up too,(in NJ) so you never know if you will pass unless you try. worst that can happen is you fail.
  6. #6 Re: Airbag Light
    Mar 2012
    Oregon
    Yea my air bag light is still on and dnt know what to do.
  7. #7 Re: Airbag Light
    St. Louis
    Have it scanned for codes.
    Mercer, Pa
    They sell scanners for ABS and Airbag codes now. Check your make and model. $86. Worked on my 03 Bonneville.
    http://www.amazon.com/gp/aw/d/B004OO...00_i00_details
  9. #9 Re: Airbag Light
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    pull the cluster off locate the airbag light and remove the bulb, then pass inspection
    Dec 2010
    DMV
    Quote Originally Posted by asite57 View Post
    I am SO CLOSE TO DOING THIS.
    Just to stop seeing this damn light lol
  11. #11 Re: Airbag Light
    Oct 2011
    Michigan
    i did it to the washer fluid light on a different car it had a leak in the line and just pissed me off always being on
  12. #12 Re: Airbag Light
    Quote Originally Posted by sseilmnop View Post
    OTC 9450 Bilingual OBD II Scan Tool, ABS and Airbag (SRS) Code Reader:Amazon:Automotive
    I just bought this I'll be happy when it gets here so i can read abs codes now if i ever get one.
  1. 97 GTP: Airbag light
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 08-14-2011, 07:37 PM
  2. knock sensor and airbag light
    By 08pontiacgxp in forum 5.3L V8 (LS4)
    Last Post: 09-25-2010, 11:26 AM
  3. SRS airbag light on
    By Haulero in forum General Tech Discussion
    Last Post: 12-17-2009, 09:24 PM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
