Thread: Spark plugs and wires
Results 1 to 7 of 7
  1. #1 Spark plugs and wires
    Feb 2010
    West Virginia
    Hey I have read the article about modding your gtp but I would like a clearer answer on something. Don't use iridium plugs with super charged cars? My car has 130,000 easy miles and needs a tune up(slight miss.) I AM NOT GOING RADICAL, Daily driver. Most i see myself doing horespower wise would possibly be CAI. With that said, which plug do I want to use and 7mm or 8mm wires? I have already changed fluids and filters prior to that excellent article, and I mean it. That was a very good article. Thanks for the help. Like everybody, I am trying to save money but I get a really good discount at the local parts store. I just did not want to by something that would hurt the motor. By the way, I pulled plugs that are in it. Not original AC 401's that showed signs of wear.
  2. #2 Re: Spark plugs and wires
    if youre not going anywhere fast with the car its not going to matter what plugs or wires you buy. we just recommend copper plugs because they work well with boosted motors. you can run some platinums if youd like, but they just dont perform as well. copper plugs are also cheap and plugs are easy to change with every other oil change.
    for the wires, just replace the stock ones with another delco set.
  3. #3 Re: Spark plugs and wires
    Feb 2010
    West Virginia
    Thanks for the help. So the iridium wont hurt the motor?
  4. #4 Re: Spark plugs and wires
    it wont hurt it, its just not ideal. i would still recommend platinums over iridiums.
  5. #5 Re: Spark plugs and wires
    Feb 2010
    West Virginia
    Thanks I think I will save some money with the delco platinums.
  6. #6 Re: Spark plugs and wires
    Feb 2010
    West Virginia
    Thanks for the help. I had free time this weekend so I did the tune up. I replaced the plugs with delco iridiums and new delco wires. Idle was smooth. I hadn't used Accel coil packs before so I decided to try them. I returned the Accel packs today. The car would barely idle. Old delcos are back on with no miss and smooth acceleration.
  7. #7 Re: Spark plugs and wires
    Portland Oregon
    If you're going platinum plugs go with AC 41-932's. They're 1 heat range colder. So even though you're not modded or won't be modding heavily it might cure any kr you have right now.
  1. Spark Plugs and Wires
    By FormulaW66 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2010, 04:55 PM
  2. Best plugs&wires for a 99 GTP
    By MurphysLaw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 08:58 AM
  3. Plugs and Wires
    By Squishy in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-09-2009, 09:51 PM
  4. New Spark Plugs and Wires
    By rileystanek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 02:31 AM
