Quote Originally Posted by shiguy View Post
you need new bearings for your wheels. almost 90% positive. I had the same problem on mine. I would replace them, they would warp, have to get new ones. Finally i checked and when jacked up there was a very small movement in the wheel that i could wiggle (we're talking small like only a few millimeters). Keep in mind though any movement will cause warping and there should be NONE. I replaced the bearings in the hub and never warped since. All the GM vehicles from that time had ****ty wheel bearings on them and they go bad. The worst was the Caviliers. My ex had to get all 4 bearings replaced. I've had to replace 2 but one was because the ABS wires snapped inside and i couldn't get to them to solder them.
Just a question, I thought you needed to replace the hub assembly to do the wheel bearings on these cars? Please correct me if i'm wrong...
