Thread: brake rotors warped
Results 1 to 20 of 24
Threaded View
  1. #8 Re: brake rotors warped
    Lusby
    Quote Originally Posted by Will5600 View Post
    My dads 03 GTP he has gone threw 3 pairs of front rotors because they keep warping. they are drilled and slotted can anyone help me idk what to do
    you need new bearings for your wheels. almost 90% positive. I had the same problem on mine. I would replace them, they would warp, have to get new ones. Finally i checked and when jacked up there was a very small movement in the wheel that i could wiggle (we're talking small like only a few millimeters). Keep in mind though any movement will cause warping and there should be NONE. I replaced the bearings in the hub and never warped since. All the GM vehicles from that time had ****ty wheel bearings on them and they go bad. The worst was the Caviliers. My ex had to get all 4 bearings replaced. I've had to replace 2 but one was because the ABS wires snapped inside and i couldn't get to them to solder them.
  1. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  2. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
  3. V 12 brake shop rotors
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2008, 02:40 PM
