Thread: brake rotors warped
Results 1 to 20 of 24
  1. #1 Re: brake rotors warped
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    I had the same issue with mine until I bought and installed these.
    Brembo Replacement Rotor
  2. #2 Re: brake rotors warped
    Canterbury, CT
    Quote Originally Posted by MBruneaux View Post
    The pulsation is back, I found play in my right bearing so I'm replacing them both.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  3. #3 Re: brake rotors warped
    Lusby
    Bingo! what did i tell ya. Like i said i was going through rotors every few months. Replaced my bearings 5 years ago and have never warped a rotor since.
  4. #4 Re: brake rotors warped
    Donating Users Warbeaver's Avatar
    St. Louis
    Drilled and Slotted rotors are amazing compared to stockers. The ones he is using must be cheap-o's. If you want good D/S rotors...then buy them from R1 Concepts off of EBay.
    not that i like to agree with Nick ...
    but x2. I have had these on 2 cars with no problems. stopping is excellent. Drilled rotors actually prevent warping
  5. #5 Re: brake rotors warped
    Quote Originally Posted by Warbeaver View Post
    Drilling doesnt improve cooling.
    Vent your dust plates. You could probably autocross with 11" front rotors if you did that with some quality solid rotors and high temp pads.
  6. #6 Re: brake rotors warped
    St. Louis
    actually it does. drilled rotors are cooler than blanks. the holes reduce surface area, which lowers friction, which lowers heat. the holes dissapate the heat too.
    the main purpose, is to release the gas that builds up during braking between the rotor and pad, which can deteriorate the rotor. It can also release debri that builds up between the rotor and pad
  1. Brake Pads and rotors
    By packerfanjc in forum General Tech Discussion
    Last Post: 01-20-2010, 09:49 PM
  2. Brake pads for d/s rotors
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 03:24 PM
  3. V 12 brake shop rotors
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-23-2008, 02:40 PM
